    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 27.0k Views 3 Watching
      dazza120 @sdetweil
      @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
        sudo nano /etc/motion/motion.conf
        nano or whatever editor you choose…
          also just noticed that the execute bit is not set on the script… SO
          cd modules/MMM-SleepWake
          chmod +x external_motion
          D 1 Reply Last reply
            dazza120 @sdetweil
            @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
              sdetweil @dazza120
              @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                dazza120 @sdetweil
                @sdetweil im leaving it with the ; in the command line?
                  sdetweil @dazza120
                  @dazza120 the example doesn’t have ;
                  on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
                    dazza120 @sdetweil
                    @sdetweil no it this is what its like i hope this is correct?
                    # Command to be executed when an event starts. (default: none)
                    # An event starts at first motion detected after a period of no motion defined $
                    ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
                    # Command to be executed when an event ends after a period of no motion
                    # (default: none). The period of no motion is defined by option event_gap.
                    ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
                      ok, that ; is a comment in the motion conf file, just like #… have to remove it
                      note that the on event end has an extra token there that neds to be removed
                      on_event_end value
                        dazza120 @sdetweil
                        @sdetweil yes it is do i have to remove the # aswell?
                          sdetweil @dazza120
                          @dazza120 no, there is no # on those two lines
                            dazza120 @sdetweil
                            @sdetweil no on the two lines above it
                              sdetweil @dazza120
                              @dazza120 no, those are comments to explain what these lines do
                                dazza120 @sdetweil
                                @sdetweil ok cool so this is how i have it now
                                # An event starts at first motion detected after a period of no motion defined by event_gap
                                 on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                                  sdetweil @dazza120
                                  @dazza120 looks good
                                    dazza120 @sdetweil
                                    @sdetweil thanks ive done this command chmod +x external_motion but i don’t see an outcome it just re turns to pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake
                                    whole commandline below
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ chmod +x external_motion
                                      sdetweil @dazza120
                                      @dazza120 right. That makes my script executable, so motion can execute it
                                      Now u will see files appear in the MMM-SleepWake/motion folder
                                      When the motion module detects motion, and when it ends.
                                      My module uses those files
                                      Reply Quote 2
                                        @sdetweil u start the motion tool with sudo motion &
                                        And u can see it’s actions in /var/log/motion/motion.log
                                        The tail command will show you the last few lines (default 20) of a file
                                        D 2 Replies Last reply
                                        Reply Quote 2
                                          dazza120 @sdetweil
                                          @sdetweil i’ll have a look tomorrow, thanks very much for your help much appreciated for your help
                                            dazza120 @sdetweil
                                            @sdetweil not sure its supposed to look like this
                                            pi@raspberrypi:~ $ sudo motion &
                                            [1] 28276
                                            pi@raspberrypi:~ $ [0:motion] [ALR] [ALL] conf_load: could not open configfile /usr/local/etc/motion/motion.conf: No such file or directory
                                            [0:motion] [CRT] [ALL] conf_load: No config file to process, using default values
                                            [0:motion] [NTC] [ALL] motion_startup: Using default log level (NTC) (6)
                                            [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
                                            [0:motion] [NTC] [ALL] motion_startup: Motion 4.2.1+git20181209-7bd179c Started
                                            [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
                                            [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (NTC)
                                            [0:motion] [NTC] [ENC] ffmpeg_global_init: ffmpeg libavcodec version 57.64.101 libavformat version 57.56.101
                                            [0:motion] [NTC] [ALL] translate_init: Language: English
                                            [0:motion] [NTC] [ALL] motion_start_thread: Camera ID: 0 Camera Name: (null) Device: /dev/video0
                                            [0:motion] [NTC] [ALL] main: Waiting for threads to finish, pid: 28281
                                            [1:ml1] [NTC] [ALL] motion_init: Camera 0 started: motion detection Enabled
                                            [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                            [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                            [1:ml1] [NTC] [VID] v4l2_device_capability: - VIDEO_CAPTURE
                                            [1:ml1] [NTC] [VID] v4l2_device_capability: - READWRITE
                                            [1:ml1] [NTC] [VID] v4l2_device_capability: - STREAMING
                                            [1:ml1] [NTC] [VID] v4l2_input_select: Name = "ov534"- CAMERA
                                            [1:ml1] [NTC] [VID] v4l2_norm_select: Device does not support specifying PAL/NTSC norm
                                            [1:ml1] [NTC] [VID] v4l2_pixfmt_select: Configuration palette index 17 (YU12) for 640x480 doesn't work.
                                            M 1 Reply Last reply
                                            • 2 / 3
