    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 24.8k Views 3 Watching
      dazza120 @sdetweil
      @sdetweil thank you, i have located it with your help, ill work on this when im not at work thanks, so its just a case of adding one of your scripts? think ill just use the start one
        sdetweil @dazza120
        @dazza120 its just one script… external_motion… you pass it a parm, started or ended
        you need to configue both started and ended, else it can’t sleep thinking motion is still going on
        note that because it is in the /etc folder tree, you must use sudo in front of your editor to get write permission
          dazza120 @sdetweil
          @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
            sudo nano /etc/motion/motion.conf
            nano or whatever editor you choose…
              also just noticed that the execute bit is not set on the script… SO
              cd modules/MMM-SleepWake
              chmod +x external_motion
                dazza120 @sdetweil
                @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                  sdetweil @dazza120
                  @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                    dazza120 @sdetweil
                    @sdetweil im leaving it with the ; in the command line?
                      sdetweil @dazza120
                      @dazza120 the example doesn’t have ;
                      on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
                        dazza120 @sdetweil
                        @sdetweil no it this is what its like i hope this is correct?
                        # Command to be executed when an event starts. (default: none)
                        # An event starts at first motion detected after a period of no motion defined $
                        ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
                        # Command to be executed when an event ends after a period of no motion
                        # (default: none). The period of no motion is defined by option event_gap.
                        ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
                          ok, that ; is a comment in the motion conf file, just like #… have to remove it
                          note that the on event end has an extra token there that neds to be removed
                          on_event_end value
                            dazza120 @sdetweil
                            @sdetweil yes it is do i have to remove the # aswell?
                              sdetweil @dazza120
                              @dazza120 no, there is no # on those two lines
                                dazza120 @sdetweil
                                @sdetweil no on the two lines above it
                                  sdetweil @dazza120
                                  @dazza120 no, those are comments to explain what these lines do
                                    dazza120 @sdetweil
                                    @sdetweil ok cool so this is how i have it now
                                    # An event starts at first motion detected after a period of no motion defined by event_gap
                                     on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                                      sdetweil @dazza120
                                      @dazza120 looks good
                                        dazza120 @sdetweil
                                        @sdetweil thanks ive done this command chmod +x external_motion but i don’t see an outcome it just re turns to pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake
                                        whole commandline below
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ chmod +x external_motion
                                          sdetweil @dazza120
                                          @dazza120 right. That makes my script executable, so motion can execute it
                                          Now u will see files appear in the MMM-SleepWake/motion folder
                                          When the motion module detects motion, and when it ends.
                                          My module uses those files
                                            @sdetweil u start the motion tool with sudo motion &
                                            And u can see it’s actions in /var/log/motion/motion.log
                                            The tail command will show you the last few lines (default 20) of a file
                                            D 2 Replies Last reply Reply Quote 2
                                            • 2 / 3
