    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 26.5k Views 3 Watching
      motion config is done in /etc/motion/motion.conf
      i just added a line in the readme about that
        dazza120 @sdetweil
        @sdetweil thank you, i have located it with your help, ill work on this when im not at work thanks, so its just a case of adding one of your scripts? think ill just use the start one
          sdetweil @dazza120
          @dazza120 its just one script… external_motion… you pass it a parm, started or ended
          you need to configue both started and ended, else it can’t sleep thinking motion is still going on
          note that because it is in the /etc folder tree, you must use sudo in front of your editor to get write permission
            dazza120 @sdetweil
            @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
              sudo nano /etc/motion/motion.conf
              nano or whatever editor you choose…
                also just noticed that the execute bit is not set on the script… SO
                cd modules/MMM-SleepWake
                chmod +x external_motion
                  dazza120 @sdetweil
                  @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                    sdetweil @dazza120
                    @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                      dazza120 @sdetweil
                      @sdetweil im leaving it with the ; in the command line?
                        sdetweil @dazza120
                        @dazza120 the example doesn’t have ;
                        on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
                          dazza120 @sdetweil
                          @sdetweil no it this is what its like i hope this is correct?
                          # Command to be executed when an event starts. (default: none)
                          # An event starts at first motion detected after a period of no motion defined $
                          ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
                          # Command to be executed when an event ends after a period of no motion
                          # (default: none). The period of no motion is defined by option event_gap.
                          ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
                            ok, that ; is a comment in the motion conf file, just like #… have to remove it
                            note that the on event end has an extra token there that neds to be removed
                            on_event_end value
                              dazza120 @sdetweil
                              @sdetweil yes it is do i have to remove the # aswell?
                                sdetweil @dazza120
                                @dazza120 no, there is no # on those two lines
                                  dazza120 @sdetweil
                                  @sdetweil no on the two lines above it
                                    sdetweil @dazza120
                                    @dazza120 no, those are comments to explain what these lines do
                                      dazza120 @sdetweil
                                      @sdetweil ok cool so this is how i have it now
                                      # An event starts at first motion detected after a period of no motion defined by event_gap
                                       on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                                        sdetweil @dazza120
                                        @dazza120 looks good
                                          dazza120 @sdetweil
                                          @sdetweil thanks ive done this command chmod +x external_motion but i don’t see an outcome it just re turns to pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake
                                          whole commandline below
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ chmod +x external_motion
                                            sdetweil @dazza120
                                            @dazza120 right. That makes my script executable, so motion can execute it
                                            Now u will see files appear in the MMM-SleepWake/motion folder
                                            When the motion module detects motion, and when it ends.
                                            My module uses those files
                                            • 2 / 3
