    Unsuccessful video streaming - help please :)
    14 Posts 4 Posters 5.7k Views 3 Watching
      mwoodage
      Hello, can anyone help, i’ve tried everything i can think of…
      I’m getting the following error when i start up Magic Mirror,
      Starting stream stream1 with args: [
      “–avdict”,
      “rtsp_transport:tcp”,
      “–win”,
      “334, 796, 686, 1038”,
      “–live”,
      “–video_queue”,
      “4”,
      “–fps”,
      “30”,
      “rtsp://admin:*******@192.168.1.77:554//h264Preview_01_main”
      Starting PM2 for omx_stream1
      PM2 started for omx_stream1
      Whoops! There was an uncaught exception…
      TypeError: Cannot read property ‘omxRestart’ of undefined
      at pm2.start (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:156:85)
      at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1017:21
      at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1088:19
      at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:473:16
      at iterateeCallback (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:992:24)
      at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:969:16
      at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1084:9
      at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
      at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
      at emitOne (events.js:116:13)
      Stopping stream stream1
      Stopping PM2 process: omx_stream1
      Any help would be gratefully received.
      Martin
      • evroomE Offline
        evroom
        @mwoodage
        Do you have the parameter “omxRestart” in your MMM-RTSPStream config ?
        I assume you are using this module.
        If yes, I would try to comment out (//) this parameter.
        Or set it to 0 (omxRestart: 0,).
        MagicMirror version: 2.36.0
          mwoodage
          Hi evroom, thanks for the help - I’ve searched for “omxRestart” in the config but found nothing. :(
            shbatm Module Developer
            @mwoodage There are some issues with the latest release of that module. Please try reverting to an older version and see if it works. I am in the process of working on a fix for it:
            cd ~/MagicMirror/modules/MMM-RTSPStream
            git checkout f583553
              mwoodage
              Thanks @shbatm - that’s cured the errors but i’m still not getting the video feed. It could be my settings so will try that first and report back.
              Thanks again
              Martin
                shbatm Module Developer @mwoodage
                @mwoodage Make sure you can reach the stream in VLC or something similar first. Then try using the args that were spit out in the log to run omxplayer by itself from the command line. You may have to play with the arguments until you can get it work by itself, then you can change the module settings to match.
                omxplayer –avdict rtsp_transport:tcp –win 334 796 686 1038 –live –video_queue 4 –fps 30 “rtsp://admin:*******@192.168.1.77:554//h264Preview_01_main”
                • evroomE Offline
                  evroom
                  A few hours ago I was busy with this module too, as it stopped to work after I loaded the latest changes.
                  I deleted and re-installed the module again; am on the origin/master branch.
                  For me, the stream only started after this command:
                  pm2 start omx_stream1
                  Perhaps worth a try.
                  With
                  pm2 list
                  you can see if omx_stream1 is online.
                  Then I saved the pm2 config to make it boot resistant
                  pm2 update
                  pm2 save
                  Btw, I do not see the
                  in the pm2 logs anymore.
                    mwoodage
                    Thanks shbatm - i’ve tried the stream several times on my laptop and it shows up without any problems. I’ve now installed VLC player on the Raspberry Pi and i can’t get the feed to work. I’m using exactly the same on both - any ideas?
                    rtsp://admin:*******@192.168.1.77/h264Preview_01_main
                      mwoodage
                      hi evroom, thanks for the help,
                      I tried what you said (after installing PM2!) but i just get the following:-
                      pi@raspberrypi:~ $ pm2 start omx_stream1
                      [PM2][ERROR] script not found : /home/pi/omx_stream1
                      │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
                      Use pm2 show <id|name> to get more details about an app
                      pi@raspberrypi:~ $
                      Is that right?? I’m assuming not, as its saying script not found. I’ve un-installed omx player and re-installed it but get the same results.
                      Sorry, i’m completely new to this so please be patient with me :)
                      • evroomE Offline
                        evroom
                        Did you setup auto start according to this procedure?
                        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                        Perhaps it worked for me because the omx_stream was already known by pm2 in my case.
                        Perhaps it needs to run once for pm2 to be useful.
                        No idea.
                        pm2 list
                        Only shows mm, or MagicMirror?
                          @mwoodage The stream didn’t work in VLC player either (e.g. VLC by itself, nothing to do with MagicMirror)? Have you tried on your regular computer? Not playing in VLC may be signs of a bigger problem–unfortunately I can’t troubleshoot every camera out there… if you can get it working in VLC on the Pi, I can help try and get it working in the module.
                          Also FYI to you and @evroom, I am working on an update to the module to use VLC to play the videos instead of OMXPlayer – see details here: https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/163
                            bhepler Module Developer @mwoodage
                            @mwoodage - Not to worry, we’ll get you sorted out.
                            For starters, you are missing the script omx_stream1. pm2 has nothing to run so it can’t monitor the process. Or at least, that script isn’t located in /home/pi/
                              mwoodage
                              Hi everyone, thanks for your help so far.
                              Yesterday i wiped my RP clean and started a fresh install - however I still can’t get the camera stream to show up in the VLC player.
                              Is it because the camera is 5MP and therefore there’s too much data for the VLC player to process?
                              The same stream works on my laptop?
                              Martin
                                @mwoodage said in Unsuccessful video streaming - help please :):
                                That may be the case. Most cameras offer a second, lower-resolution stream that you could use for something like the mirror.
