    Unsuccessful video streaming - help please :)
    14 Posts 4 Posters 5.4k Views 3 Watching
    • evroomE Offline
      evroom
      @mwoodage
      Do you have the parameter “omxRestart” in your MMM-RTSPStream config ?
      I assume you are using this module.
      If yes, I would try to comment out (//) this parameter.
      Or set it to 0 (omxRestart: 0,).
      MagicMirror version: 2.33.0
      Test environment:
      MagicMirror version: v2.33.0
        mwoodage
        Hi evroom, thanks for the help - I’ve searched for “omxRestart” in the config but found nothing. :(
          shbatm Module Developer
          @mwoodage There are some issues with the latest release of that module. Please try reverting to an older version and see if it works. I am in the process of working on a fix for it:
          cd ~/MagicMirror/modules/MMM-RTSPStream
          git checkout f583553
            mwoodage
            Thanks @shbatm - that’s cured the errors but i’m still not getting the video feed. It could be my settings so will try that first and report back.
            Thanks again
            Martin
              shbatm Module Developer @mwoodage
              @mwoodage Make sure you can reach the stream in VLC or something similar first. Then try using the args that were spit out in the log to run omxplayer by itself from the command line. You may have to play with the arguments until you can get it work by itself, then you can change the module settings to match.
              omxplayer –avdict rtsp_transport:tcp –win 334 796 686 1038 –live –video_queue 4 –fps 30 “rtsp://admin:*******@192.168.1.77:554//h264Preview_01_main”
              • evroomE Offline
                evroom
                A few hours ago I was busy with this module too, as it stopped to work after I loaded the latest changes.
                I deleted and re-installed the module again; am on the origin/master branch.
                For me, the stream only started after this command:
                pm2 start omx_stream1
                Perhaps worth a try.
                With
                pm2 list
                you can see if omx_stream1 is online.
                Then I saved the pm2 config to make it boot resistant
                pm2 update
                pm2 save
                Btw, I do not see the
                Starting stream stream1 with args
                in the pm2 logs anymore.
                Test environment:
                  mwoodage
                  Thanks shbatm - i’ve tried the stream several times on my laptop and it shows up without any problems. I’ve now installed VLC player on the Raspberry Pi and i can’t get the feed to work. I’m using exactly the same on both - any ideas?
                  rtsp://admin:*******@192.168.1.77/h264Preview_01_main
                    mwoodage
                    hi evroom, thanks for the help,
                    I tried what you said (after installing PM2!) but i just get the following:-
                    pi@raspberrypi:~ $ pm2 start omx_stream1
                    [PM2][ERROR] script not found : /home/pi/omx_stream1
                    │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
                    Use pm2 show <id|name> to get more details about an app
                    pi@raspberrypi:~ $
                    Is that right?? I’m assuming not, as its saying script not found. I’ve un-installed omx player and re-installed it but get the same results.
                    Sorry, i’m completely new to this so please be patient with me :)
                    • evroomE Offline
                      evroom
                      Did you setup auto start according to this procedure?
                      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                      Perhaps it worked for me because the omx_stream was already known by pm2 in my case.
                      Perhaps it needs to run once for pm2 to be useful.
                      No idea.
                      pm2 list
                      Only shows mm, or MagicMirror?
                      Test environment:
                        @mwoodage The stream didn’t work in VLC player either (e.g. VLC by itself, nothing to do with MagicMirror)? Have you tried on your regular computer? Not playing in VLC may be signs of a bigger problem–unfortunately I can’t troubleshoot every camera out there… if you can get it working in VLC on the Pi, I can help try and get it working in the module.
                        Also FYI to you and @evroom, I am working on an update to the module to use VLC to play the videos instead of OMXPlayer – see details here: https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/163
