    Config.fs
    troubleshootconfigconfig.jsconfiguration
    22 Posts 4 Posters 8.1k Views 4 Watching
      A Former User @scoller
      @scoller said in Config.fs:
      locationID: “2726470”
      comma missed.
      99% of configuration failure was due to this mistake.
      S lavolp3L 2 Replies Last reply Reply Quote 1
        scoller @Guest
        @sean thank you
          scoller
          @sean how do i know where the comma should be? I know im stupid :)
          • lavolp3L Offline
            lavolp3 Module Developer @Guest
            @sean said in Config.fs:
            comma missed.
            A classic!
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              @scoller
              In {} (object) and [] (array), there could be several items. Each item should be separated by comma,. Only last item could omit ,.
              By example
              someObject: {
                someProperty: someValue ,
                anotherProperty: anotherValue ,
                lastProperty: lastValue
              }, //< - this object also could be an element of other list
              someArray: [
                someElement,
                otherElement,
                lastElement //< - you can omit comma here.
              ] // < - You can omit last comma of list.
              S 3 Replies Last reply Reply Quote 0
                scoller @Guest
                @sean so you mean like {nothing,nothing}?
                  @scoller right.
                    scoller @Guest
                    @sean but i mean where is the brackets where the comma should be. For an example high up or low down in the code
                      @scoller Well, that is a just grammar of JavaScript. So…
                      Hmmm…
                      Just remember these.
                      • Every bracket([], {}) should be closed somewhere.
                      • Nested brackets should be matched their opening and closing.
                      • All Items should be separated with comma
                      • All text string should be quoted by quotation mark (`, " or ')
                      • true/false (boolean value) and number should not be quoted.
                      These are common rules for config.js
                        scoller @Guest
                        @sean thank’s for the help will try that
