    Config.fs
    troubleshootconfigconfig.jsconfiguration
    22 Posts 4 Posters 8.3k Views 4 Watching
      scoller
      Thank you very much here is my config:
      /* Magic Mirror Config Sample
      • MIT Licensed.
      • For more information how you can configurate this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "Uppkommande Högtider",
      					symbol: "calendar-check",
      					url: "http://www.calendarlabs.com/templates/ical/us-holidays.ics"
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "2726470"
      			appid: "c17305e68b5d2b54d3f2c8b5e2cc4002"
      		module: "weatherforecast",
      		header: "Vädret i Framtiden",
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
      if (typeof module !== “undefined”) {module.exports = config;}
        A Former User @scoller
        @scoller said in Config.fs:
        locationID: “2726470”
        comma missed.
        99% of configuration failure was due to this mistake.
        S lavolp3L 2 Replies Last reply Reply Quote 1
          scoller @Guest
          @sean thank you
            scoller
            @sean how do i know where the comma should be? I know im stupid :)
            • lavolp3L Offline
              lavolp3 Module Developer @Guest
              @sean said in Config.fs:
              comma missed.
              A classic!
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
                @scoller
                In {} (object) and [] (array), there could be several items. Each item should be separated by comma,. Only last item could omit ,.
                By example
                someObject: {
                  someProperty: someValue ,
                  anotherProperty: anotherValue ,
                  lastProperty: lastValue
                }, //< - this object also could be an element of other list
                someArray: [
                  someElement,
                  otherElement,
                  lastElement //< - you can omit comma here.
                ] // < - You can omit last comma of list.
                S 3 Replies Last reply Reply Quote 0
                  scoller @Guest
                  @sean so you mean like {nothing,nothing}?
                    @scoller right.
                      scoller @Guest
                      @sean but i mean where is the brackets where the comma should be. For an example high up or low down in the code
                        @scoller Well, that is a just grammar of JavaScript. So…
                        Hmmm…
                        Just remember these.
                        • Every bracket([], {}) should be closed somewhere.
                        • Nested brackets should be matched their opening and closing.
                        • All Items should be separated with comma
                        • All text string should be quoted by quotation mark (`, " or ')
                        • true/false (boolean value) and number should not be quoted.
                        These are common rules for config.js
