    Config.fs
    troubleshootconfigconfig.jsconfiguration
    22 Posts 4 Posters 8.9k Views 4 Watching
      A Former User @scoller
      @scoller right.
        scoller @Guest
        @sean but i mean where is the brackets where the comma should be. For an example high up or low down in the code
          @scoller Well, that is a just grammar of JavaScript. So…
          Hmmm…
          Just remember these.
          • Every bracket([], {}) should be closed somewhere.
          • Nested brackets should be matched their opening and closing.
          • All Items should be separated with comma
          • All text string should be quoted by quotation mark (`, " or ')
          • true/false (boolean value) and number should not be quoted.
          These are common rules for config.js
            scoller @Guest
            @sean thank’s for the help will try that
              @scoller
              You have two locationID: "2726470" in your code. both should be modified.
                scoller @Guest
                @sean Specific for my code can you point it out cause I can’t find it, may be because of my lack of knowledge :)
                  scoller @Guest
                  @sean my code goes like this is this an error?
                  Hdhdhdhdu
                  Hhdhdhfhdujd.
                  Hdhdhhdh
                  And the bracket never closes, is that an error?
                    @scoller
                      module: "currentweather",
                        locationID: "2726470", // < - I think here comma missed.
                        appid: "c17305e68b5d2b54d3f2c8b5e2cc4002"
                      module: "weatherforecast",
                      header: "Vädret i Framtiden",
                        locationID: "2726470", // < - Here also.
                      scoller @Guest
                      @sean What is that? I see its the code but what?
                        @scoller
                        Exchange those with your current currentweather and weatherforecast in config.js
                          scoller @Guest
                          @sean Thank you again. Is that the problem?
                          Mykle1M ? 2 Replies Last reply Reply Quote 0
                            Mykle1 Project Sponsor Module Developer @scoller
                            @scoller
                            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                              @scoller
                              You’ve missed comma after locationID: "2726470" so, just adding it would be enough, but you’d said you couldn’t find where they are, so I told you to exchange whole section.
