    Config.fs
    troubleshootconfigconfig.jsconfiguration
    22 Posts 4 Posters 6.8k Views 4 Watching
      scoller
      I have recently downloaded the magicmirror project and started to edit the config.js sample file. After i wrote in my information such as, weather, calendar, and compliments I tried to re start the project. The project started with still a notice saying edit you config file and I cant figure out where this problem comes from. A good thing to know is that the config.js file was the sample file so I saved it with out the sample. I have also run the code through the jshint and it says alot of things that idon’t understand :). PLEASE can someone help me
      • lavolp3L Offline
        lavolp3 Module Developer @scoller
        @scoller said in Config.fs:
        Well for that we’d need to know what jshint says :-)
        Can you please post your config.js here (WITHOUT sensitive data please)
        And for the next time:
        In the magicmirror directory you can put in
        npm run config:check
        and it will also give you the errors in the config.
        You can then look up the lines using e.g.
        sudo nano -c config/config.js
        which will add the columns to nano
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          scoller
          Thank you very much here is my config:
          /* Magic Mirror Config Sample
          • MIT Licensed.
          • For more information how you can configurate this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          // - “”, “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 24,
          units: "metric",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "Uppkommande Högtider",
          					symbol: "calendar-check",
          					url: "http://www.calendarlabs.com/templates/ical/us-holidays.ics"
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "2726470"
          			appid: "c17305e68b5d2b54d3f2c8b5e2cc4002"
          		module: "weatherforecast",
          		header: "Vädret i Framtiden",
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "New York Times",
          			showSourceTitle: true,
          			showPublishDate: true
          if (typeof module !== “undefined”) {module.exports = config;}
            A Former User @scoller
            locationID: “2726470”
            comma missed.
            99% of configuration failure was due to this mistake.
            S lavolp3L 2 Replies Last reply Reply Quote 1
              scoller @Guest
              @sean thank you
                scoller
                @sean how do i know where the comma should be? I know im stupid :)
                • lavolp3L Offline
                  lavolp3 Module Developer @Guest
                  @sean said in Config.fs:
                  comma missed.
                  A classic!
                    @scoller
                    In {} (object) and [] (array), there could be several items. Each item should be separated by comma,. Only last item could omit ,.
                    By example
                    someObject: {
                      someProperty: someValue ,
                      anotherProperty: anotherValue ,
                      lastProperty: lastValue
                    }, //< - this object also could be an element of other list
                    someArray: [
                      someElement,
                      otherElement,
                      lastElement //< - you can omit comma here.
                    ] // < - You can omit last comma of list.
                    S 3 Replies Last reply Reply Quote 0
                      scoller @Guest
                      @sean so you mean like {nothing,nothing}?
                        @scoller right.
