    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 942.6k Views 74 Watching
      j.e.f.f Project Sponsor Module Developer @Arjan
      @arjan yes. Here are a few config options for you:
      showCurrentConditions: false will turn off the main icon and the current temparature display (the two big items).
      showExtraCurrentConditions: false will turn off the the additional current conditions immediately below the big icon and temperature.
      This module is programmed it with this type of usage in mind, so it supports multiple instances to work independently. I do something similar on my kitchen display centre.
      A 1 Reply Last reply
      • A
        Arjan Project Sponsor @j.e.f.f
        @j-e-f-f Thanks. I overlooked that one.
          j.e.f.f Project Sponsor Module Developer @dan-o
          @dan-o said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          Looks like I spoke too soon :(. Was working after a restart. Walked by the mirror just now and no icon present.
          @dan-o @Smotx I think I’ve licked the disappearing icon issue for good now. I tested a fix on my mirror for 24 hours, and the icon was visible every time I checked up on it. Please do a git pull in the MMM-DarkSkyForecast directory and restart MM. Let me know if it’s fixed.
            dan-o
            @j-e-f-f Pulled just now. Will let you know if I run into the issue again!
            Appreciate ya!
              Johans @j.e.f.f
              @j-e-f-f installed latest version of your nicely build weather forecast module, but now I see that my personal web player is not working anymore.
              All content is displayed on the mirror, but there is no reaction when I press a play button (seems play buttons are disabled)
              To show the player on my mirror I’ve abused the widget module.
              It shows me 6 radio stations and a selection button for MP3’s on the SD card of the raspberry. (All simple stuff – so far no rocket science)
              I’m sure problem is related towards the installation of your weather module, as I did a rebuild on another SD card to try -out.
              Removing and re-installing your module or the widget module was no solution so far.
              Started mirror in dev mode, but here also I don’t see any problem.
              As I read here that you updated this module to use the Nunjucks html templating system, I suspect it has a relation with my html code I’m using in the widget module.
              See below code in the config. Perhaps somebody can port this code according the Nunjucks html. (sound lick chinees for me  )
                 		disabled: false,
                 		module: "MMM-Widget",
                    	        position: "middle_center",
                  		pages: {"Page1": "lower_third"},
                 		widgets: [
                 	        { //insert your script or html codes here.
                 	        html:`
                                     <!-- TradingView Widget BEGIN -->
                 		<html lang="en">
                 		<head>
                 		<title>JSTAL MIRROR PLAYER</title>
                 		<meta charset="UTF-8">
                 		<meta name="viewport" content="width=device-width, initial-scale=1">
                 		<link rel="stylesheet" type="text/css" href="http://localhost:8080/modules/MyPlayer/css/styles.css">   <!-- page design -->
                 	        <link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css">
                 		<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>  <!-- For audio play -->
                 		<style>
                 		</style>
                 		</head>
                 		<body>
                 		<div class="header">
                 		  <h1>Mirror Webradio / MP3 Player</h1>
                 		</div>
                 		<div class="row">
                 		  <div class="main">
                 		     <p>My Radio Stations</p>
                 			 <img src="http://localhost:8080/modules/MyPlayer/images/JoeFM.jpg" style="width:5%;">
                 			 <audio id="myAudio0" src="http://icecast-qmusic.cdp.triple-it.nl:80/JOEfm_be_live_128.mp3" preload="false" controls="true" volume="1.0"></audio>
                 		     <script>   <!-- Script play pause toggle -->
                 			 var myAudio0 = document.getElementById("myAudio0");
                 				function togglePlay() {
                 				return myAudio0.paused ? myAudio0.play() : myAudio0.pause();
                 			 </script> <br>
                 			 <img src="https://upload.wikimedia.org/wikipedia/commons/0/09/Qmusiclogo2015red.jpg" style="width:5%;">
                 			 <audio id="myAudio1" src="http://icecast-qmusic.cdp.triple-it.nl:80/Qmusic_be_live_96.mp3" preload="false" controls="true" volume="1.0"></audio>
                 			 var myAudio1 = document.getElementById("myAudio1");
                 				return myAudio1.paused ? myAudio1.play() : myAudio1.stoppause();
                 			 </script> <br>
                 			 <img src="https://pbs.twimg.com/profile_images/1612540320/FAMILYRADIO_LOGO_WEB_400x400.jpg" style="width:5%;">
                 			 <audio id="myAudio2" src="http://www.clubfmserver.be:8000/family.mp3" preload="false" controls="true" volume="1.0"></audio>
                 			 var myAudio2 = document.getElementById("myAudio2");
                 				return myAudio2.paused ? myAudio2.play() : myAudio2.pause();
                 			 </script> <br>
                 		    <img src="https://upload.wikimedia.org/wikipedia/commons/3/36/MNM_logo.png" style="width:5%;">
                 			 <audio id="myAudio3" src="http://icecast.vrtcdn.be/mnm_hits-high.mp3" preload="false" controls="true" volume="1.0"></audio>
                 			 var myAudio3 = document.getElementById("myAudio3");
                 				return myAudio3.paused ? myAudio3.play() : myAudio3.pause();
                 			 </script> <br>
                 		     <img src="https://upload.wikimedia.org/wikipedia/commons/thumb/1/19/Radio_2_Logo.svg/1000px-Radio_2_Logo.svg.png" style="width:5%;">
                 			 <audio id="myAudio4" src="http://icecast.vrtcdn.be/ra2ovl-high.mp3" preload="false" controls="true" volume="1.0"></audio>
                 			 var myAudio4 = document.getElementById("myAudio4");
                 				return myAudio4.paused ? myAudio4.play() : myAudio4.pause();
                 			 </script> <br>
                 		     <img src="https://pbs.twimg.com/profile_images/1476072724/Logo-alta-resolucao-MusicCityGame.jpg" style="width:5%;">
                 			 <audio id="myAudio5" src="http://stream2.intronic.nl:80/citymusic" preload="false" controls="true" volume="1.0"></audio>
                 			 var myAudio5 = document.getElementById("myAudio5");
                 				return myAudio5.paused ? myAudio5.play() : myAudio5.pause();
                 			 </script> <br>
                 		        <hr><p>Select and Play MP3 from Local database folder </p>
                 		        <input type="file" id="songs" multiple> <br> <br>
                 			<i class="fa fa-music"></i>
                 		        <audio controls id="myAudio" autoplay></audio>
                 					var songs = document.getElementById("songs"),
                 						myAudio = document.getElementById("myAudio");
                 						function next(n){
                 						  var url = URL.createObjectURL(files[n]);
                 						  myAudio.setAttribute('src', url);
                 						  myAudio.play();
                 						var _next = 0,
                 						files,
                 						len;
                 						songs.addEventListener('change', function() {
                 						  files = songs.files;
                 						  len = files.length;
                 						  if(len){
                 						next(_next);
                 						myAudio.addEventListener("ended", function(){
                 						   _next += 1;
                 						   next(_next);
                 						   console.log(len, _next);
                 						   if((len-1)==_next){
                 						 _next=-1;
                 				 </script>
                 		</body>
                 		<!-- TradingView Widget END -->
                                     `,    // Ends of Widget - important to set!
                 	        width: "460px",
                 	        height: "525px",
                 	        backgroundColor: "#256d7b"   //"#FFF"
              For people interested here the CSS details as well.
              /* add here some separate css data */
              /* Style the body margin: 0  */
              body {
                  font-family: Arial;
                  margin: auto;
                  width: 450px;
                  height: 500px;
                  border: 3px solid #256d7b;
              /* Header/logo Title  - color = #1abc9c/#008080  of #256d7b */
              .header {
                  padding: 5px;
                  text-align: center;
                  background: #256d7b;
                  color: white;
              /* Increase the font size of the heading */
              .header h1 {
                  font-size: 20px;
              /* Main column   color = #fcfcfc or white */
              .main {
                  -ms-flex: 60%; /* IE10 */
                  flex: 60%;
                  background-color: #fcfcfc;
                  padding: 20px;
                  text-align: center;
              /* Draw up a vertical line */
              hr.vertical
                 width: 5px;
                 height: 100%; /* or height in PX */
              .slider {
                position: absolute;
                cursor: pointer;
                top: 0;
                left: 0;
                right: 0;
                bottom: 0;
                background-color: #ca2222;
                -webkit-transition: .4s;
                transition: .4s;
                 border-radius: 34px;
              .slider:before {
                position: absolute;
                content: "";
                height: 26px;
                width: 26px;
                left: 4px;
                bottom: 4px;
                background-color: white;
                transition: .4s;
                border-radius: 50%;
              input:checked + .slider {
                background-color: #2ab934;
              input:focus + .slider {
                box-shadow: 0 0 1px #2196F3;
              input:checked + .slider:before {
                -webkit-transform: translateX(26px);
                -ms-transform: translateX(26px);
                transform: translateX(55px);
              /*------ ADDED CSS ---------*/
              .slider:after
               content:'OFF';
               color: white;
               display: block;
               position: absolute;
               transform: translate(-50%,-50%);
               top: 50%;
               left: 50%;
               font-size: 10px;
               font-family: Verdana, sans-serif;
              input:checked + .slider:after
                content:'ON';
              Maybe there are other ways to embed my player on the mirror, but for now MMM-Widget was the only thing I found to do.
              Hope somebody can help me out.
              Thx.
              J J 2 Replies Last reply
                j.e.f.f Project Sponsor Module Developer @Johans
                @johans If you disable the MMM-DarkSkyForecast module do you get your web player functionality back?
                J 1 Reply Last reply
                  Johans @Johans
                  @johans
                  I’ll guess something went wrong when I paste the code
                  			disabled: false,
                  			widgets: [
                  		        html:`
                  			<html lang="en">
                  			<head>
                  			<style>
                  			</style>
                  			</head>
                  			<body>
                  			</div>
                  			<div class="row">
                  			  <div class="main">
                  				 </script> <br>
                  				 </script> <br>
                  				 </script> <br>
                  				 </script> <br>
                  				 </script> <br>
                  				 </script> <br>
                  							function next(n){
                  							  myAudio.play();
                  							var _next = 0,
                  							files,
                  							len;
                  							  len = files.length;
                  							  if(len){
                  							next(_next);
                  							   _next += 1;
                  							   next(_next);
                  							   if((len-1)==_next){
                  							 _next=-1;
                  					 </script>
                  			</body>
                  		        width: "460px",
                  		        height: "525px",
                    Johans @j.e.f.f
                    @j-e-f-f
                    No, It doesn’t come back.
                    I made a new installation on fresh SD card.
                    All works fine without installing your module, after that it’s not working anymore.
                      Johans @Johans
                      When I run directly in the browser, it’s OK, but thats not the main goal, should run via the MagicMirror.
                      • H
                        hco125
                        I posted an issue on your module link in GitHub, but no response yet. Please see this link for details. Both the config in the link as well as the one below do the same thing…loading infinitely.
                        			module: 'MMM-DarkSkyForecast',
                        			header: "Weather",
                        			position: 'top_center',
                        			disabled: false,
                        				updateInterval: 10,
                        				units: 'us',
                        				forecastHeaderText: "O'Neill, NE",
                        				iconset: '5c',
                        				apiKey: 'blocked for privacy',
                        				latitude: '42.457649',
                        				longitude: '-98.647789',
                        				forecastLayout: 'tiled',```
                        lavolp3L 1 Reply Last reply
                        • lavolp3L
                          lavolp3 Module Developer @hco125
                          @hco125
                          Time to go do some debugging. Ican imagine noone will be able to help you with the information given.
                          Please do the following:
                          Start the mirror in dev mode
                          npm start dev
                          OR
                          Open the mirror webpage on another browser (MIRRORIP:8080), press F12 for dev mode
                          In both cases, try to find error messages referring to this module and post them here.
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                          N 1 Reply Last reply
                          • H
                            hco125
                            I stripped down my MagicMirror configuration as well, so that we know that another module is not interfering. The modules that ARE on this config include: alert, updatenotification, MMM-ModuleScheduler, clock, MMM-AlarmClock, MMM-DarkSkyForecast, and MMM-Screencast. Here are the errors in the console running MagicMirror and accessing on Chrome with those modules running.
                            moment-timezone-with-data.js:472 Moment Timezone has no data for none. See http://momentjs.com/timezone/docs/#/data-loading/.
                            logError	@	moment-timezone-with-data.js:472
                            57
                            fn.tz	@	moment-timezone-with-data.js:554
                            getDom	@	clock.js:79
                            (anonymous)	@	main.js:110
                            updateDom	@	main.js:109
                            updateDom	@	main.js:514
                            updateDom	@	module.js:358
                            (anonymous)	@	clock.js:45
                            However, I then stripped ALL modules EXCEPT MMM-DarkSkyForecast and rechecked the console. I get NO errors, and the log is as follows, but the modules still loads infinitely, with no display of weather (see screenshot, below):
                            Initializing MagicMirror.
                            translator.js:201 Loading core translation file: translations/en.json
                            translator.js:224 Loading core translation fallback file: translations/en.json
                            loader.js:182 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
                            module.js:469 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: 2.6.0
                            module.js:471 Version is ok!
                            module.js:477 Module registered: MMM-DarkSkyForecast
                            loader.js:152 Bootstrapping module: MMM-DarkSkyForecast
                            loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                            loader.js:182 Load script: modules/MMM-DarkSkyForecast/skycons.js
                            loader.js:157 Scripts loaded for: MMM-DarkSkyForecast
                            loader.js:197 Load stylesheet: modules/MMM-DarkSkyForecast/MMM-DarkSkyForecast.css
                            loader.js:159 Styles loaded for: MMM-DarkSkyForecast
                            loader.js:161 Translations loaded for: MMM-DarkSkyForecast
                            loader.js:197 Load stylesheet: css/custom.css
                            MMM-DarkSkyForecast.js:138 Starting module: MMM-DarkSkyForecast
                            main.js:468 All modules started!
                            module.js:156 MMM-DarkSkyForecast received a system notification: ALL_MODULES_STARTED
                            module.js:156 MMM-DarkSkyForecast received a system notification: MODULE_DOM_CREATED
                            module.js:156 MMM-DarkSkyForecast received a system notification: DOM_OBJECTS_CREATED
                            So after adding in one module at a time to determine which one was throwing the errors I posted above, it is the default MagicMirror “clock” module, and I do not believe it is the cause of the MMM-DarkSkyForecast problems.
                              @johans @hco125 i believe your issues are related. If the module runs in the web browser, but not on the mirror, then we’re seeing an issue with the difference in JavaScript syntax supported by Chrome versus Electron. I’ll need to debug your configs in Electron running on the Pi, as the errors will only be seen in the browser console.
                              Sorry I’ve been slow to respond. I just got back from visiting family for the holidays so I haven’t been checking this forum at all nor the issue list in my git repo. Will take a look and let you know if I find any problems.
                                djsunrise19
                                Looks very nice. Is there a way to get the “feels like” temperature, too? I can’t find anything about it.
                                • H
                                  hco125
                                  @j-e-f-f & @lavolp3
                                  I figured out the issue…idiot error (me). I typed the config option as “apiKey” instead of “apikey” and it wouldn’t read it as registered. So sorry for taking your time. Works now.
                                    j.e.f.f Project Sponsor Module Developer @djsunrise19
                                    @djsunrise19 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                    I’m planning to add it. This is something I’d like as well.
                                      @johans said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                      @j-e-f-f
                                      Can you try something? Completely remove MMM-DarkSkyForecast (i.e.delete the directory with rmdir -rf MMM-DarkSkyForecast), and comment out the entry in the config. Restart MM. Does your player come back now? If so, try this:
                                      Reinstall my module using git clone ... but DON’T run npm install in the MMM-DarkSkyForecast directory. All of the dependencies are currently included with Magic Mirror, so it should work as-is.
                                      Put the DarkSky entry back in your config and restart MM. If everything works then the issue is that my module is installing a different version of one of the dependencies than what is included in MM, and likely is causing the incompatibility with the MMM-Widget module.
                                      • richland007R
                                        richland007
                                        @j-e-f-f Thank you for this nice weather module :)
                                        I do have a strange occurrence happening however… no matter if i use ca, us, si for units in front of every high temperature number i get a square… the temperature is displayed along with that square … what is that??
                                        Oh another thing …how can i make the background of your module non transparent/black or semi transparent?? I am trying to use the @Sean MMM-WeatherBackground and the majority of pictures are too bright to read this module.
                                        • Cr4z33C
                                          Cr4z33 @j.e.f.f
                                          • richland007R
                                            richland007
                                            Any ideas at what those squares are in front of my temperature numbers everybody ?? ;)
                                            • 16
                                            • 17
                                            • 4 / 17
