    basic help
    5 Posts 4 Posters 1.9k Views 4 Watching
      cade72
      Hi, I am very new to everything(sorry) and have a question. it would be awesome if someone helped.
      I followed this from what I understood was I should put this
      		module: "clock",
      			displaySeconds: false,
      	                clockBold: true,
      this didnt work and now I feel dumb:face_with_tears_of_joy: any help would be awesome. this is kinda my first time I have dabbled in programming so sorry again for the basic question.
      T Mykle1M 2 Replies Last reply
      • T
        THeStigh @cade72
        @cade72 You forgot a comma after the last bracket :)
          and for the future, if u have problems with config.js syntax errors, in the MagicMirror folder run
          node tests/configs/check_config.js
          it will report the problems. start & fix from the top
          edit: wrong name for the checker… (removed extra s on the end)
          Reply Quote 2
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @cade72
            @cade72
            You could give this a quick read. It tries to explain config entries in the simplest of terms.
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
              cade72
              thanks everyone, this helped a lot!
