    Setting Up Magic Mirror on Ubuntu issue
    11 Posts 5 Posters 4.6k Views 5 Watching
      DuhCompuder
      I’ve tried the manual install. After going through several audit installs, this is the final one that I could not get through. Anyone have any experience in resolving this issue?
      Note: I’m using ubuntu mate on my pi 3 instead of Raspbian
      justjim1220J 1 Reply Last reply
      • justjim1220J
        justjim1220 Module Developer @DuhCompuder
        @duhcompuder
        npm i lodash@4.17.5
        this fixed mine
        Jim Hallock - 1995
          DuhCompuder
          Thank you, I was able to fix the lodash issue only through a root terminal.
          But a warning pops up saying:
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed.
          You must install peer dependencies yourself.
          I read somewhere that this could be an npm issue or a bug. Still trying to figure it out. The issue now is to find acorn@^6.0.0 and the location to install it to. Hopefully that should fix the issue, any ideas?
          • justjim1220J
            @duhcompuder
            Install the same way: npm i acorn@latest
            with any of those kind of warnings do the same.
            I’m having issues right now getting MM to run on a new install of Ubuntu.
            Keep getting errors that the sh start.sh or something like that isn’t valid.
            Can’t figure it out, had this issue once before a long time ago and not sure how I fixed it.
            Jim Hallock - 1995
            D 1 Reply Last reply
              DuhCompuder @justjim1220
              I don’t even know how to describe this… So after fixing the acorn issue, the lodash issue reappeared. For some reason, I can no longer fix the lodash issue (even with sudo and root terminal). It just would not let me install lodash 4.17.5 or even the newest version because of the vulnerability.
              I’m hypothesizing that MM might be using something that is dependent on a previous version of lodash that conflicts with Ubuntu’s security vulnerability
              Here is an article referring the lodash vulnerabilities existing in versions prior to 4.17.11:
              https://resources.whitesourcesoftware.com/blog-whitesource/top-5-open-source-security-vulnerabilities-november-2018
              Conclusion.
              After updating my system’s lodash file to 4.17.12 through a root terminal, I was able to resolve updating issues related to lodash within the MM directory. The only issue is the message about the vulnerability that is not resolvable with npm audit fix
              Starting the program displays the message that MagicMirror is online yet the UI does not change.
              I’m going to stick with Raspbian for now
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @DuhCompuder
                @duhcompuder said in Setting Up Magic Mirror on Ubuntu issue:
                I don’t know if this matters but I use ubuntu 16.04 LTS exclusively on several machines, including my dev machine. The one time I tried to install MM on ubuntu 18.xx I encountered all the vulnerabilities that you are talking about. I immediately wiped the machine and installed ubuntu 16.04 LTS. Then I installed MM without a single problem. That includes the most current MM, v2.6.0
                T 1 Reply Last reply
                • T
                  THeStigh @Mykle1
                  @mykle1 said in Setting Up Magic Mirror on Ubuntu issue:
                  @Mykle1
                  I’ve just installed Ubuntu 14.04 on my laptop (to get full support for Snowboy), but when I run ‘npm start’, it starts the application but dont “open the magicmirror”. I can use my browser to dial into it.
                  Do you know if I need to add something extra to make it show upon running the application?
                  I run GNOME as desktop.
                  S Mykle1M 2 Replies Last reply
                    sdetweil @THeStigh
                    @thestigh i just upgraded to 2.6.0
                    this is what I see in the console window when I do npm start, obviously some of these modules are specific for my system
                    Starting MagicMirror: v2.6.0
                    Loading config ...
                    Loading module helpers ...
                    handler helper in init
                    Module helper loaded: MMM-SleepWake
                    Module helper loaded: MMM-ImagesPhotos
                    Module helper loaded: MMM-voice
                    Module helper loaded: WaterLevels
                    All module helpers loaded.
                    Starting server on port 8086 ...
                    Server started ...
                    Connecting socket for: MMM-SleepWake
                    handler helper in start
                    Connecting socket for: MMM-ImagesPhotos
                    Starting node helper for: MMM-ImagesPhotos
                    Connecting socket for: MMM-voice
                    Starting module helper: MMM-voice
                    Connecting socket for: WaterLevels
                    Starting module: WaterLevels
                    Launching application.
                    do you see anything different?
                    npm start  dev
                    would open the developers console, and then change to the console tab to check for any errors (red text)
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @THeStigh
                      @thestigh said in Setting Up Magic Mirror on Ubuntu issue:
                      No, you shouldn’t need anything “extra” although I only use ubutnu 16.04 LTS. I’m reading through some posts that mention the same exact problem that you’re experiencing, where MM is running but can only be seen remotely.
                      As suggested by @sdetweil, run npm start dev in your MagicMirror directory and choose the Console tab in the resulting window. Then copy/paste/report any errors there and/or in your terminal.
                      You might also want to make sure that all updates have been performed on your current ubuntu installation as well as ensuring that you have current stable versions of node and npm.
                        sdetweil @Mykle1
                        also check the node and npm versions,
                        node -v
                        and
                        npm -v
                        • T
                          THeStigh
                          Guys, I’m giving up this task of getting Debian/Ubuntu running on an amd64 with MMM-Hotword. I again are getting the “invalid pointer” error.
                          Perhaps this is happening only on amd64 distro and would not happen on i386 (32bit).
                          If I’m going to test it? Maybe, but returning back to my Pi and Tinker Board for now…
