    Attempting To Update
    11 Posts 6 Posters 6.2k Views 5 Watching
    • K Offline
      KumarTRD
      Attempting to update y MagicMirror and getting the following…0_1548302466116_3c1adce9-d2de-4ef9-963f-f6fa6ea1cea1-image.png
      Bild Text
      Can anyone help out here… this is my first time updating since I started playing with my pi last year.
      • U Offline
        Ultimatum22 Module Developer
        Those files are auto created by the system, you can safely remove them.
        rm package-lock.json
        rm vendor/package-lock.json
        In order to update git requires that no local files have changes, that is what the error message means.
        Those files should really be in a .gitignore file but that is another issues. Removing the files should solve your issue.
        lavolp3L K 3 Replies Last reply Reply Quote 1
        • lavolp3L Offline
          lavolp3 Module Developer @Ultimatum22
          @ultimatum22 said in Attempting To Update:
          So why aren’t we putting them in? I still don’t really know what their purpose is.
          U 1 Reply Last reply Reply Quote 0
          • U Offline
            Ultimatum22 Module Developer @lavolp3
            @lavolp3 Because they are automatically generated files, you don’t include them in a repository.
            package-lock.json is automatically generated for any operations where npm modifies either the node_modules tree, or package.json. It describes the exact tree that was generated, such that subsequent installs are able to generate identical trees, regardless of intermediate dependency updates.
            https://docs.npmjs.com/files/package-lock.json
            • lavolp3L Offline
              • K Offline
                KumarTRD @Ultimatum22
                @ultimatum22 tried what you said but got the following…
                Your help is appreciated; am I using the correct command to update my MagicMirror
                bheplerB justjim1220J 2 Replies Last reply Reply Quote 0
                • bheplerB Offline
                  bhepler Module Developer @KumarTRD
                  @kumartrd You just tried to remove the same file twice, that’s all. You’re almost there. Try:
                  And while I have you here… please use the Markdown features of the board in the future when posting code and error messages. Thanks.
                  • justjim1220J Offline
                    justjim1220 Module Developer @KumarTRD
                    @kumartrd
                    you will also need to do this:
                    cd ~/MagicMirror/vendor
                    "Life's Too Short To Dance With Ugly People"
                    Jim Hallock - 1995
                    • bheplerB Offline
                      bhepler Module Developer @justjim1220
                      @justjim1220 He already got that one.
                      • karsten13K Offline
                        karsten13
                        The git pull command fails if files are locally changed, because the pull would override them.
                        With git diff you can see what has changed.
                        If you are not interested to save these local changes you can run git reset --hard. This will revert all changes and after this the git pull should work.
