    Attempting To Update
    11 Posts 6 Posters 6.3k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @Ultimatum22
      @ultimatum22 said in Attempting To Update:
      Those files should really be in a .gitignore file but that is another issues.
      So why aren’t we putting them in? I still don’t really know what their purpose is.
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        Ultimatum22 Module Developer @lavolp3
        @lavolp3 Because they are automatically generated files, you don’t include them in a repository.
        package-lock.json is automatically generated for any operations where npm modifies either the node_modules tree, or package.json. It describes the exact tree that was generated, such that subsequent installs are able to generate identical trees, regardless of intermediate dependency updates.
        https://docs.npmjs.com/files/package-lock.json
        • lavolp3L Offline
          • K Offline
            KumarTRD @Ultimatum22
            @ultimatum22 tried what you said but got the following…
            Your help is appreciated; am I using the correct command to update my MagicMirror
            bheplerB justjim1220J 2 Replies Last reply Reply Quote 0
            • bheplerB Offline
              bhepler Module Developer @KumarTRD
              @kumartrd You just tried to remove the same file twice, that’s all. You’re almost there. Try:
              rm package-lock.json
              And while I have you here… please use the Markdown features of the board in the future when posting code and error messages. Thanks.
              • justjim1220J Offline
                justjim1220 Module Developer @KumarTRD
                @kumartrd
                you will also need to do this:
                cd ~/MagicMirror/vendor
                "Life's Too Short To Dance With Ugly People"
                Jim Hallock - 1995
                • bheplerB Offline
                  bhepler Module Developer @justjim1220
                  @justjim1220 He already got that one.
                  • karsten13K Offline
                    karsten13
                    The git pull command fails if files are locally changed, because the pull would override them.
                    With git diff you can see what has changed.
                    If you are not interested to save these local changes you can run git reset --hard. This will revert all changes and after this the git pull should work.
                    • K Offline
                      @Ultimatum22 hey there went to do the most current update and ran into the same issue with the vendor/package-lock.json package so I ran the removal script as stated below and it worked and now my pi is updated… I remember you brought up that I should have that package in a gitignore file how do I move it over?
