module for mm background
15 Posts 6 Posters 5.0k Views 6 Watching
    costascontis
    i wonder what are my options if i want to add a background to my mm.The only a know is weatherbackground.Are there other modules for this job?
    S 1 Reply Last reply Feb 1, 2019, 2:44 PM Reply Quote 0
    • S Online
      sdetweil @costascontis
      @costascontis do you want a single background, or should it change over time?
        costascontis
        if it could automatically change it will be good …
        S 1 Reply Last reply Feb 1, 2019, 2:56 PM Reply Quote 0
        • S Online
          @costascontis I use MMM-ImagePhotos, or MMM-ImageSlideshow (search on google for their github location)
          both load images from the local MM disk as background.
          I’m sure there are others too…
            rts58
            I’ve been using MMM-BackgroundSlideshow, it allows me to randomly display an image from 1000’s stored in a many level folder structure on my NAS.
            S S 2 Replies Last reply Feb 1, 2019, 5:57 PM Reply Quote 1
            • S Online
              sdetweil @rts58
              @rts58 thanks… that does almost everything my modified version does… one less thing to maintain!
              • Y Offline
                yawns Moderator
                You could also try the module @Mykle1 came up with: https://github.com/mykle1/MMM-EasyBack
                  Is the search feature broken on the forum? LOL
                  S 1 Reply Last reply Feb 2, 2019, 3:00 AM Reply Quote 0
                  • S Online
                    sdetweil @cowboysdude
                    @cowboysdude search?
                      surger13 Project Sponsor @rts58
                      @rts58 I’m interested. I would like to do it the same way, but it only works with the sample images of the module.
                      What path did you specify in config.js to access your NAS?
                      Thank you
                      @rts58 said in module for mm background:
                      S 1 Reply Last reply Feb 2, 2019, 1:58 PM Reply Quote 0
