    MMM-MyScoreboard
    277 Posts 60 Posters 641.8k Views 63 Watching
    • V
      vinp Module Developer @cyberphox
      @cyberphox can you try getting to your MM via URL in a remote browser http://yourPi-IPaddress:8080 ? You can then look at Developer Tools in Chrome/Firefox etc and dig into the image element that should be showing for each team. My fork works fine for images of the NFL. It takes the image URL via the ESPN feed for the logo. The original code, has local images for each team.
        cyberphox
        Running it in a Docker container on Synology…got it remotely open on Chrome…got the Developer Tools open…
        I do have a logos folder with all the Team logos there so not sure why only a few show
        Looks like the Was log for example is pointing to a file that does exist:
          j.e.f.f Project Sponsor Module Developer @cyberphox
          @cyberphox OH I see the problem! The file name is WAS.svg not Was.svg (Notice the difference in case). That should be an easy fix to simply force uppercase. Will publish a fix tonight.
            @cyberphox OK this should be fixed now. Do a git pull and let me know if it’s resolved for you.
              cyberphox
              How the heck did I not see this myself? I seriously even checked the first let to see if it was a capital issue…should’ve kept going! lol
              Seems fixed! Thanks man!
              • A
                Achilles
                Happy New Year all!
                I am not seeing NHL scores now. Actually, I only have one team that I am trying to follow (Tampa Bay Lightning) and that score is failing to pop up in the Scoreboard now. I did do a git pull a week ago, but my results are the same. Am I missing something?
                  j.e.f.f Project Sponsor Module Developer @Achilles
                  @achilles I messed up with the commits and in my attempt to fix it, I might have left all installs in an odd state, where a git pull doesn’t seem to work. Please delete the module directory and reinstall to get the latest code. Hopefully that will fix your issue. Give it a shot and post back letting me know if it worked.
                  • A
                    Achilles
                    @j-e-f-f Thanks!
                    That did the trick! Much appreciated for the help!
                      @achilles Glad you got it working. Also, Tampa Bay BOOOOOO!!!
                        Hey folks. I know I haven’t paid much attention to this module over the last little bit, but with the move to the UK my kids are all into Soccer now (or Football, as everyone continues to correct me!). They’ve demanded I add Arsenal and FC Barcelona to my mirror.
                        So I’ve released a new update and it’s a big one. This builds on the work that was done on the add_more_soccer branch. But instead of supporting a handlful of soccer leagues, my module now supports ALL of the soccer leagues that ESPN’s API feed provides.
                        To anyone currently using the add_more_soccer branch note that your configs won’t work as-is any more. Given that I’ve added support for more than 100 leagues and competitions, I’ve needed to come up with a more meaningful naming scheme. Please see the README for the new list of leagues supported.
                        Also, if a git pull does not get you the latest source code, then you might need to remove the module altogether and reinstall it from scratch. A while back I messed up a couple of commits and it might have left some installs in an unlinked state. Reinstalling from source gets you past that moment in time, and everything should work as normal after that.
                        Enjoy!
                        • Jeff
                        • V
                          This makes me so happy!!! Cannot wait to check it out and move away from my forked code. Welcome to the world of football!!
                            motdog
                            I got this up and running but with NCAA Mens basketball I am struggling to limit the games shown. I have tried changing the group to “Big 12” or “Top 25” but still get everygame, so the module covers the whole left side of my mirror. What am I missing? This is a fresh installation. I just set up my mirror a few days ago.
                            		  module: "MMM-MyScoreboard",
                            		  position: "bottom_left",
                            		  classes: "default everyone",
                            		  header: "My Scoreboard",
                            		    showLeagueSeparators: true,
                            		    colored: true,
                            		    viewStyle: "mediumLogos",
                            		    sports: [
                            		        league: "NHL",
                            		        groups: ["Atlantic"]
                            		        league: "NBA",
                            		        league: "MLB",
                            		        league: "NFL",
                            		        league: "NCAAM",
                            		        Groups: ["Big 12"]
                              motdog
                              Also is there a way to limit the numbers of games being shown and maybe rotate through them? Thanks for the help.
                                j.e.f.f Project Sponsor Module Developer @motdog
                                @motdog change your config to specify groups with a small g, not a capital G. That should fix it.
                                  motdog @j.e.f.f
                                  @j-e-f-f Awesome. It did!
                                    sameer-t
                                    @j-e-f-f Love the module! Any chance we can add the team’s seed for NCAA March Madness?
                                      j.e.f.f Project Sponsor Module Developer @sameer-t
                                      @sameer-t said in MMM-MyScoreboard:
                                      I’m not sure the feed gives me that info, but you can enable rankings for the top teams. It may equate to seeding since ESPN treats March Madness as an independent feed.
                                      set showRankings to true in your config. Note this is NOT where you configure the individual leagues, but in the module’s general config.
                                      • CyruS1337C
                                        CyruS1337 Project Sponsor
                                        Good day
                                        Is it also possible to add the Swiss National League?
                                        https://en.wikipedia.org/wiki/National_League_(ice_hockey)
                                          j.e.f.f Project Sponsor Module Developer @CyruS1337
                                          @CyruS1337 said in MMM-MyScoreboard:
                                          Good day
                                          If there’s an available JSON feed, I’m sure it can be done. I’m currently using feeds from ESPN and SportsNet.ca, neither of which provide score data for the Swiss National League. Do you know of one?
                                          CyruS1337C 1 Reply Last reply Reply Quote 0
                                            SH20192
                                            Is there a way to get this working in a client/server setup? If I run MM directly on my server then all is well. If I run it in client /server mode then the client just displays “loading…”
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
