    MMM-MyScoreboard
    277 Posts 60 Posters 650.2k Views 63 Watching
      motdog
      I got this up and running but with NCAA Mens basketball I am struggling to limit the games shown. I have tried changing the group to “Big 12” or “Top 25” but still get everygame, so the module covers the whole left side of my mirror. What am I missing? This is a fresh installation. I just set up my mirror a few days ago.
      		  module: "MMM-MyScoreboard",
      		  position: "bottom_left",
      		  classes: "default everyone",
      		  header: "My Scoreboard",
      		    showLeagueSeparators: true,
      		    colored: true,
      		    viewStyle: "mediumLogos",
      		    sports: [
      		        league: "NHL",
      		        groups: ["Atlantic"]
      		        league: "NBA",
      		        league: "MLB",
      		        league: "NFL",
      		        league: "NCAAM",
      		        Groups: ["Big 12"]
      J 1 Reply Last reply
        motdog
        Also is there a way to limit the numbers of games being shown and maybe rotate through them? Thanks for the help.
          j.e.f.f Project Sponsor Module Developer @motdog
          @motdog change your config to specify groups with a small g, not a capital G. That should fix it.
          M 1 Reply Last reply
            motdog @j.e.f.f
            @j-e-f-f Awesome. It did!
              sameer-t
              @j-e-f-f Love the module! Any chance we can add the team’s seed for NCAA March Madness?
                j.e.f.f Project Sponsor Module Developer @sameer-t
                @sameer-t said in MMM-MyScoreboard:
                I’m not sure the feed gives me that info, but you can enable rankings for the top teams. It may equate to seeding since ESPN treats March Madness as an independent feed.
                set showRankings to true in your config. Note this is NOT where you configure the individual leagues, but in the module’s general config.
                • CyruS1337C
                  CyruS1337 Project Sponsor
                  Good day
                  Is it also possible to add the Swiss National League?
                  https://en.wikipedia.org/wiki/National_League_(ice_hockey)
                    j.e.f.f Project Sponsor Module Developer @CyruS1337
                    @CyruS1337 said in MMM-MyScoreboard:
                    Good day
                    If there’s an available JSON feed, I’m sure it can be done. I’m currently using feeds from ESPN and SportsNet.ca, neither of which provide score data for the Swiss National League. Do you know of one?
                    CyruS1337C 1 Reply Last reply
                      SH20192
                      Is there a way to get this working in a client/server setup? If I run MM directly on my server then all is well. If I run it in client /server mode then the client just displays “loading…”
                        sdetweil @SH20192
                        @SH20192 if you open the developers window on the client, ctrl-shift-i, select the console tab and scroll up… do you find any errors? usually red text
                        S 2 Replies Last reply
                          SH20192 @sdetweil
                          @sdetweil I’ll check when I get home. Thanks!
                            SH20192 @sdetweil
                            @sdetweil said in MMM-MyScoreboard:
                            Did some troubleshooting on this. Appears to be a conflict between this modules and MMM-GoogleMapsTraffic. If I disable that module then MMM-MyScoreboard works. That modules doesn’t impact any other modules though. Attached pic is the error it shows. Any thoughts? Like I said this only does this with clientonly.
                            https://imgur.com/a/FcJbruR
                            • CyruS1337C
                              CyruS1337 Project Sponsor @j.e.f.f
                              @j-e-f-f No, unfortunately not
                                sdetweil @SH20192
                                @SH20192
                                edit MMM-Scorebpoard.js and change line 552 to
                                 Log.log("[MMM-MyScoreboard] Updating Scores");
                                • N
                                  nona @BKeyport
                                  @BKeyport
                                  I also encountered with same problem. I tried troubleshooting but it didn’t worked for me. i created my account with the help of onlyfans hack.
                                  • L
                                    lotusvball
                                    Trying to install this and there is an issue with cryptiles . It won’t install and need upgraded cryptiles to version 4.1.3.
                                    StoffbeuteluweS 1 Reply Last reply
                                    • StoffbeuteluweS
                                      Stoffbeuteluwe Project Sponsor @lotusvball
                                      @lotusvball for me it works fine, I have set up German leagues
                                      L 1 Reply Last reply
                                      • L
                                        lotusvball @Stoffbeuteluwe
                                        @Stoffbeuteluwe So I misunderstood the message. It installs but gives a high vulnerability warning. It still needs to be fixed to fix the vulnerability.
                                          sdetweil @lotusvball
                                          @lotusvball sometimes u can fix those…
                                          npm audit fix
                                          sometimes u can’t as no fix is available yet
                                          • L
                                            lotusvball
                                            tried that and it say that it needs done manually. I see the code in the .js part but don’t know how to fix it.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
