    MMM-MyScoreboard
    277 Posts 60 Posters 634.4k Views 63 Watching
      j.e.f.f Project Sponsor Module Developer @sameer-t
      @sameer-t said in MMM-MyScoreboard:
      @j-e-f-f Love the module! Any chance we can add the team’s seed for NCAA March Madness?
      I’m not sure the feed gives me that info, but you can enable rankings for the top teams. It may equate to seeding since ESPN treats March Madness as an independent feed.
      set showRankings to true in your config. Note this is NOT where you configure the individual leagues, but in the module’s general config.
      • CyruS1337C Offline
        CyruS1337 Project Sponsor
        Good day
        Is it also possible to add the Swiss National League?
        https://en.wikipedia.org/wiki/National_League_(ice_hockey)
          j.e.f.f Project Sponsor Module Developer @CyruS1337
          @CyruS1337 said in MMM-MyScoreboard:
          Good day
          If there’s an available JSON feed, I’m sure it can be done. I’m currently using feeds from ESPN and SportsNet.ca, neither of which provide score data for the Swiss National League. Do you know of one?
          CyruS1337C 1 Reply Last reply Reply Quote 0
            SH20192
            Is there a way to get this working in a client/server setup? If I run MM directly on my server then all is well. If I run it in client /server mode then the client just displays “loading…”
              sdetweil @SH20192
              @SH20192 if you open the developers window on the client, ctrl-shift-i, select the console tab and scroll up… do you find any errors? usually red text
                SH20192 @sdetweil
                @sdetweil I’ll check when I get home. Thanks!
                  SH20192 @sdetweil
                  @sdetweil said in MMM-MyScoreboard:
                  Did some troubleshooting on this. Appears to be a conflict between this modules and MMM-GoogleMapsTraffic. If I disable that module then MMM-MyScoreboard works. That modules doesn’t impact any other modules though. Attached pic is the error it shows. Any thoughts? Like I said this only does this with clientonly.
                  https://imgur.com/a/FcJbruR
                    CyruS1337 Project Sponsor @j.e.f.f
                    @j-e-f-f No, unfortunately not
                      sdetweil @SH20192
                      @SH20192
                      edit MMM-Scorebpoard.js and change line 552 to
                       Log.log("[MMM-MyScoreboard] Updating Scores");
                      • N Offline
                        nona @BKeyport
                        @BKeyport
                        I also encountered with same problem. I tried troubleshooting but it didn’t worked for me. i created my account with the help of onlyfans hack.
                        • L Offline
                          lotusvball
                          Trying to install this and there is an issue with cryptiles . It won’t install and need upgraded cryptiles to version 4.1.3.
                          • StoffbeuteluweS Offline
                            Stoffbeuteluwe Project Sponsor @lotusvball
                            @lotusvball for me it works fine, I have set up German leagues
                            • L Offline
                              lotusvball @Stoffbeuteluwe
                              @Stoffbeuteluwe So I misunderstood the message. It installs but gives a high vulnerability warning. It still needs to be fixed to fix the vulnerability.
                                sdetweil @lotusvball
                                @lotusvball sometimes u can fix those…
                                npm audit fix
                                sometimes u can’t as no fix is available yet
                                • L Offline
                                  lotusvball
                                  tried that and it say that it needs done manually. I see the code in the .js part but don’t know how to fix it.
                                  • L Offline
                                    lucallmon
                                    @j-e-f-f is there a way you can change how often it updates the scores? what is the default set to? I’d like to change it to every 15 minutes. Thanks and standing by.
                                      smoysauce
                                      Any clue why it would only show Final score and not future or in progress? I have been looking through the code, comparing the ESPN feed to everything I can’t seem to figure it out.
                                      • E Offline
                                        ensch25
                                        Is there a way to change the time format into a 24h look?
                                          socosurf
                                          Is anyone else not having NBA scores populate? Is the module not supposed to show the scrimmage scores?
                                            j.e.f.f Project Sponsor Module Developer @socosurf
                                            @socosurf the module gets its scores from a SportsNet.ca feed. If you see scores for games on their web site, then you should see them in the module. But I don’t think SportsNet has historically had exhibition games in their feed.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
