    MMM-MyScoreboard
    277 Posts 60 Posters 642.8k Views 63 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @lotusvball
      @lotusvball for me it works fine, I have set up German leagues
      L 1 Reply Last reply
      • L
        lotusvball @Stoffbeuteluwe
        @Stoffbeuteluwe So I misunderstood the message. It installs but gives a high vulnerability warning. It still needs to be fixed to fix the vulnerability.
          sdetweil @lotusvball
          @lotusvball sometimes u can fix those…
          npm audit fix
          sometimes u can’t as no fix is available yet
          • L
            lotusvball
            tried that and it say that it needs done manually. I see the code in the .js part but don’t know how to fix it.
            • L
              lucallmon
              @j-e-f-f is there a way you can change how often it updates the scores? what is the default set to? I’d like to change it to every 15 minutes. Thanks and standing by.
                smoysauce
                Any clue why it would only show Final score and not future or in progress? I have been looking through the code, comparing the ESPN feed to everything I can’t seem to figure it out.
                • E
                  ensch25
                  Is there a way to change the time format into a 24h look?
                    socosurf
                    Is anyone else not having NBA scores populate? Is the module not supposed to show the scrimmage scores?
                    J 2 Replies Last reply
                      j.e.f.f Project Sponsor Module Developer @socosurf
                      @socosurf the module gets its scores from a SportsNet.ca feed. If you see scores for games on their web site, then you should see them in the module. But I don’t think SportsNet has historically had exhibition games in their feed.
                        @socosurf actually I think for NBA the feed is from ESPN. In any case, same general idea applies. If you don’t see scores for these matches in the web site then you won’t see it in the module.
                          motdog
                          MLS scores don’t seem to be updating. Am I the only one with issues?
                            JRichardson10
                            Hi complete coding and raspberry pie newbie here, I was wondering if it’s possible to add a code sequence that allows you to only show the results from one sports division/league at a time and fade between all the listed divisions/leagues I’ve included in config.js file, similar to how it’s fades between each sports league table in the ‘MMM-MyStandings’ module. I’ve tried looking through the ‘MMM-MyScoreboard.js’ file but cannot find any solution.
                            Apologies if this is a really simple solution, I’m very new to this😅. Any help would be greatly appreciated!
                            • E
                              Egnos
                              Hi everyone, many thanks for the module, it is really beautiful!
                              Is it possible to freeze match results until the next match?
                              Now after the games have finished the results disappear …
                              BKeyportB 1 Reply Last reply
                              • BKeyportB
                                BKeyport Module Developer @Egnos
                                @Egnos Short answer: No. Long Answer: Noooooooooooooooooooooooooooooooooooooo.
                                Due to the data feeds, the match is cleared as soon as they set up the new ones. You’d be better off to use a module specific to your target league for that, where the author took the time to cache results.
                                E 1 Reply Last reply
                                • E
                                  Egnos @BKeyport
                                  @BKeyport thanks.
                                  If I set “rolloverHours” configuration parameter with a very high number … like 100?
                                  When the match schedule is updated would it change?
                                    mcaminiti
                                    • sifuhallS
                                      sifuhall
                                      I followed the instructions here for the git pull and npm install with no errors.
                                      In my config file I place this but all I get is a blank screen.
                                      module: “MMM-MyScoreboard”,
                                      position: “top_left”,
                                      classes: “default everyone”,
                                      header: “My Scoreboard”,
                                      showLeagueSeparators: true,
                                      colored: true,
                                      viewStyle: “mediumLogos”,
                                      sports: [
                                      league: “NCAAF”,
                                      teams: [“UK”]
                                      W 1 Reply Last reply
                                      • W
                                        Wenike @sifuhall
                                        @sifuhall You won’t get anything until the UK football team has a game, which won’t be for a few weeks. Until then, this module displays nothing.
                                        sifuhallS 1 Reply Last reply
                                        • sifuhallS
                                          sifuhall @Wenike
                                          @wenike Thank you for the reply. But I’m saying the entire screen is blank. Not just the scores section.
                                          W S 2 Replies Last reply
                                          • W
                                            Wenike @sifuhall
                                            @sifuhall So, other modules aren’t showing either?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
