    MMM-MyScoreboard
    277 Posts 60 Posters 623.2k Views 63 Watching
    • L Offline
      lucallmon
      @j-e-f-f is there a way you can change how often it updates the scores? what is the default set to? I’d like to change it to every 15 minutes. Thanks and standing by.
        smoysauce
        Any clue why it would only show Final score and not future or in progress? I have been looking through the code, comparing the ESPN feed to everything I can’t seem to figure it out.
        • E Offline
          ensch25
          Is there a way to change the time format into a 24h look?
            socosurf
            Is anyone else not having NBA scores populate? Is the module not supposed to show the scrimmage scores?
              j.e.f.f Project Sponsor Module Developer @socosurf
              @socosurf the module gets its scores from a SportsNet.ca feed. If you see scores for games on their web site, then you should see them in the module. But I don’t think SportsNet has historically had exhibition games in their feed.
                @socosurf actually I think for NBA the feed is from ESPN. In any case, same general idea applies. If you don’t see scores for these matches in the web site then you won’t see it in the module.
                  motdog
                  MLS scores don’t seem to be updating. Am I the only one with issues?
                    JRichardson10
                    Hi complete coding and raspberry pie newbie here, I was wondering if it’s possible to add a code sequence that allows you to only show the results from one sports division/league at a time and fade between all the listed divisions/leagues I’ve included in config.js file, similar to how it’s fades between each sports league table in the ‘MMM-MyStandings’ module. I’ve tried looking through the ‘MMM-MyScoreboard.js’ file but cannot find any solution.
                    Apologies if this is a really simple solution, I’m very new to this😅. Any help would be greatly appreciated!
                    • E Offline
                      Egnos
                      Hi everyone, many thanks for the module, it is really beautiful!
                      Is it possible to freeze match results until the next match?
                      Now after the games have finished the results disappear …
                      • BKeyportB Offline
                        BKeyport Module Developer @Egnos
                        @Egnos Short answer: No. Long Answer: Noooooooooooooooooooooooooooooooooooooo.
                        Due to the data feeds, the match is cleared as soon as they set up the new ones. You’d be better off to use a module specific to your target league for that, where the author took the time to cache results.
                        • E Offline
                          Egnos @BKeyport
                          @BKeyport thanks.
                          If I set “rolloverHours” configuration parameter with a very high number … like 100?
                          When the match schedule is updated would it change?
                            mcaminiti
                            • sifuhallS Offline
                              sifuhall
                              I followed the instructions here for the git pull and npm install with no errors.
                              In my config file I place this but all I get is a blank screen.
                              module: “MMM-MyScoreboard”,
                              position: “top_left”,
                              classes: “default everyone”,
                              header: “My Scoreboard”,
                              showLeagueSeparators: true,
                              colored: true,
                              viewStyle: “mediumLogos”,
                              sports: [
                              league: “NCAAF”,
                              teams: [“UK”]
                              • W Offline
                                Wenike @sifuhall
                                @sifuhall You won’t get anything until the UK football team has a game, which won’t be for a few weeks. Until then, this module displays nothing.
                                sifuhallS 1 Reply Last reply Reply Quote 0
                                • sifuhallS Offline
                                  sifuhall @Wenike
                                  @wenike Thank you for the reply. But I’m saying the entire screen is blank. Not just the scores section.
                                  W S 2 Replies Last reply Reply Quote 0
                                  • W Offline
                                    Wenike @sifuhall
                                    @sifuhall So, other modules aren’t showing either?
                                      sdetweil @sifuhall
                                      @sifuhall this sounds like the the missing libraries problem. when the screen is blank, can u show the message at mm startup?
                                      if using pm2, use
                                      pm2 logs --lines=100
                                      • sifuhallS Offline
                                        sifuhall @sdetweil
                                        Yes, this was it exactly. Once I added the request module everything was fine.
                                        However, I do have one question.
                                        How can I add the West Ham United Football Club?
                                        • BKeyportB Offline
                                          BKeyport Module Developer @sifuhall
                                          @sifuhall it looks like it’s not supported based on the code.
                                          • sifuhallS Offline
                                            sifuhall @BKeyport
                                            @bkeyport Thank you for the reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
