    MMM-MyScoreboard
    277 Posts 60 Posters 634.4k Views 63 Watching
      smoysauce
      Any clue why it would only show Final score and not future or in progress? I have been looking through the code, comparing the ESPN feed to everything I can’t seem to figure it out.
      • E Offline
        ensch25
        Is there a way to change the time format into a 24h look?
          socosurf
          Is anyone else not having NBA scores populate? Is the module not supposed to show the scrimmage scores?
            j.e.f.f Project Sponsor Module Developer @socosurf
            @socosurf the module gets its scores from a SportsNet.ca feed. If you see scores for games on their web site, then you should see them in the module. But I don’t think SportsNet has historically had exhibition games in their feed.
              @socosurf actually I think for NBA the feed is from ESPN. In any case, same general idea applies. If you don’t see scores for these matches in the web site then you won’t see it in the module.
                motdog
                MLS scores don’t seem to be updating. Am I the only one with issues?
                  JRichardson10
                  Hi complete coding and raspberry pie newbie here, I was wondering if it’s possible to add a code sequence that allows you to only show the results from one sports division/league at a time and fade between all the listed divisions/leagues I’ve included in config.js file, similar to how it’s fades between each sports league table in the ‘MMM-MyStandings’ module. I’ve tried looking through the ‘MMM-MyScoreboard.js’ file but cannot find any solution.
                  Apologies if this is a really simple solution, I’m very new to this😅. Any help would be greatly appreciated!
                  • E Offline
                    Egnos
                    Hi everyone, many thanks for the module, it is really beautiful!
                    Is it possible to freeze match results until the next match?
                    Now after the games have finished the results disappear …
                    • BKeyportB Offline
                      BKeyport Module Developer @Egnos
                      @Egnos Short answer: No. Long Answer: Noooooooooooooooooooooooooooooooooooooo.
                      Due to the data feeds, the match is cleared as soon as they set up the new ones. You’d be better off to use a module specific to your target league for that, where the author took the time to cache results.
                      • E Offline
                        Egnos @BKeyport
                        @BKeyport thanks.
                        If I set “rolloverHours” configuration parameter with a very high number … like 100?
                        When the match schedule is updated would it change?
                          mcaminiti
                          • sifuhallS Offline
                            sifuhall
                            I followed the instructions here for the git pull and npm install with no errors.
                            In my config file I place this but all I get is a blank screen.
                            module: “MMM-MyScoreboard”,
                            position: “top_left”,
                            classes: “default everyone”,
                            header: “My Scoreboard”,
                            showLeagueSeparators: true,
                            colored: true,
                            viewStyle: “mediumLogos”,
                            sports: [
                            league: “NCAAF”,
                            teams: [“UK”]
                            • W Offline
                              Wenike @sifuhall
                              @sifuhall You won’t get anything until the UK football team has a game, which won’t be for a few weeks. Until then, this module displays nothing.
                              sifuhallS 1 Reply Last reply Reply Quote 0
                              • sifuhallS Offline
                                sifuhall @Wenike
                                @wenike Thank you for the reply. But I’m saying the entire screen is blank. Not just the scores section.
                                W S 2 Replies Last reply Reply Quote 0
                                • W Offline
                                  Wenike @sifuhall
                                  @sifuhall So, other modules aren’t showing either?
                                    sdetweil @sifuhall
                                    @sifuhall this sounds like the the missing libraries problem. when the screen is blank, can u show the message at mm startup?
                                    if using pm2, use
                                    pm2 logs --lines=100
                                    • sifuhallS Offline
                                      sifuhall @sdetweil
                                      Yes, this was it exactly. Once I added the request module everything was fine.
                                      However, I do have one question.
                                      How can I add the West Ham United Football Club?
                                      • BKeyportB Offline
                                        BKeyport Module Developer @sifuhall
                                        @sifuhall it looks like it’s not supported based on the code.
                                        • sifuhallS Offline
                                          sifuhall @BKeyport
                                          @bkeyport Thank you for the reply
                                          • E Offline
                                            Egnos
                                            Hello everybody,
                                            I’m having trouble with this module, are any of you using it?
                                            The following errors MM returns me:
                                            [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] 2-Sep-22 10:52 ** ERROR ** Couldn't retrieve ITA_SERIE_A data for provider ESPN: Error: getaddrinfo ENOTFOUND site.api.espn.com
                                            [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] http://site.api.espn.com/apis/site/v2/sports/soccer/ita.1/scoreboard?dates=20220902&limit=200
                                            Starting module: MMM-MyScoreboard MMM-MyScoreboard.js:560
                                            All modules started!
                                            MMM-MyScoreboard.js:552
                                            [MMM-MyScoreboard] Updating Scores module.js:195
                                            MMM-MyScoreboard is suspended.
                                            Below my configuration
                                            		  module: "MMM-MyScoreboard",
                                            		  classes: "default everyone",
                                            		  header: "My Scoreboard",
                                            			colored: true,
                                            			viewStyle: "mediumLogos",
                                            			sports: [
                                            				league: "ITA_SERIE_A",
                                            				//teams: ["JUV"]
                                            				//label: "Seria A TIM 2022/23"
                                            Can you help me?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
