    MMM-MyScoreboard
    277 Posts 60 Posters 650.1k Views 63 Watching
    • CyruS1337C
      CyruS1337 Project Sponsor
      Good day
      Is it also possible to add the Swiss National League?
      https://en.wikipedia.org/wiki/National_League_(ice_hockey)
      J 1 Reply Last reply
        j.e.f.f Project Sponsor Module Developer @CyruS1337
        @CyruS1337 said in MMM-MyScoreboard:
        Good day
        If there’s an available JSON feed, I’m sure it can be done. I’m currently using feeds from ESPN and SportsNet.ca, neither of which provide score data for the Swiss National League. Do you know of one?
        CyruS1337C 1 Reply Last reply
          SH20192
          Is there a way to get this working in a client/server setup? If I run MM directly on my server then all is well. If I run it in client /server mode then the client just displays “loading…”
            sdetweil @SH20192
            @SH20192 if you open the developers window on the client, ctrl-shift-i, select the console tab and scroll up… do you find any errors? usually red text
            S 2 Replies Last reply
              SH20192 @sdetweil
              @sdetweil I’ll check when I get home. Thanks!
                SH20192 @sdetweil
                @sdetweil said in MMM-MyScoreboard:
                Did some troubleshooting on this. Appears to be a conflict between this modules and MMM-GoogleMapsTraffic. If I disable that module then MMM-MyScoreboard works. That modules doesn’t impact any other modules though. Attached pic is the error it shows. Any thoughts? Like I said this only does this with clientonly.
                https://imgur.com/a/FcJbruR
                • CyruS1337C
                  CyruS1337 Project Sponsor @j.e.f.f
                  @j-e-f-f No, unfortunately not
                    sdetweil @SH20192
                    @SH20192
                    edit MMM-Scorebpoard.js and change line 552 to
                     Log.log("[MMM-MyScoreboard] Updating Scores");
                    • N
                      nona @BKeyport
                      @BKeyport
                      I also encountered with same problem. I tried troubleshooting but it didn’t worked for me. i created my account with the help of onlyfans hack.
                      • L
                        lotusvball
                        Trying to install this and there is an issue with cryptiles . It won’t install and need upgraded cryptiles to version 4.1.3.
                        StoffbeuteluweS 1 Reply Last reply
                        • StoffbeuteluweS
                          Stoffbeuteluwe Project Sponsor @lotusvball
                          @lotusvball for me it works fine, I have set up German leagues
                          L 1 Reply Last reply
                          • L
                            lotusvball @Stoffbeuteluwe
                            @Stoffbeuteluwe So I misunderstood the message. It installs but gives a high vulnerability warning. It still needs to be fixed to fix the vulnerability.
                              sdetweil @lotusvball
                              @lotusvball sometimes u can fix those…
                              npm audit fix
                              sometimes u can’t as no fix is available yet
                              • L
                                lotusvball
                                tried that and it say that it needs done manually. I see the code in the .js part but don’t know how to fix it.
                                • lucallmonL
                                  lucallmon
                                  @j-e-f-f is there a way you can change how often it updates the scores? what is the default set to? I’d like to change it to every 15 minutes. Thanks and standing by.
                                    smoysauce
                                    Any clue why it would only show Final score and not future or in progress? I have been looking through the code, comparing the ESPN feed to everything I can’t seem to figure it out.
                                    • E
                                      ensch25
                                      Is there a way to change the time format into a 24h look?
                                        socosurf
                                        Is anyone else not having NBA scores populate? Is the module not supposed to show the scrimmage scores?
                                        J 2 Replies Last reply
                                          j.e.f.f Project Sponsor Module Developer @socosurf
                                          @socosurf the module gets its scores from a SportsNet.ca feed. If you see scores for games on their web site, then you should see them in the module. But I don’t think SportsNet has historically had exhibition games in their feed.
                                            @socosurf actually I think for NBA the feed is from ESPN. In any case, same general idea applies. If you don’t see scores for these matches in the web site then you won’t see it in the module.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
