    Magic mirror first try (France, ~Lille)
    50 Posts 16 Posters 51.1k Views 14 Watching
      mmourcia
      Here is my first magicmirror.
      Pictures :
      Hardware :
      Screen : https://www.amazon.fr/gp/product/B073NTCT4Q/ref=ppx_yo_dt_b_asin_title_o08__o00_s01?ie=UTF8&psc=1
      Power : https://www.amazon.fr/gp/product/B002TMG8OE/ref=ppx_yo_dt_b_asin_title_o08__o00_s00?ie=UTF8&psc=1
      RPI 3
      Sound : https://www.kubii.fr/claviers-et-peripheriques-usb/1850-mini-haut-parleurs-usb-kubii-3272496006980.html?search_query=Mini+Haut-Parleurs+USB&results=7
      Mirror : Mirropane™ Chrome Spy 6 mm / SMART MIRROR / SPIONSPIEGEL (70cmx50cm)
      Modules :
      MMM-Sound : used to play wav file when someone is calling at the intercom (doorbird)
      MMM-Iframe : showing picture from doorbird when someone is here
      MMM-Remote : turn on/off screen during the night and used by a my jeedom system with xiaomi button
      Calendar : used with google calendar
      Currentweather
      Weatherforecast
      MMM-Rain-Forecast-FR
      MMM-Netatmo-Thermostat
      MMM-Jeedom
      MMM-Strava
      MMM-Ping
      MMM-MyCommute
      1 Reply Last reply Reply Quote 7
        bhepler Module Developer
        Very nice. I like the way you positioned & mounted the smaller monitor inside a larger frame.
        • cowboysdudeC
          WOW very nicely done :)
          • ChrisC
            Chris
            Bonjour,
            Joli travail.
            Je regardais le module MMM-Rain-Forecast mais j’avais cru comprendre qu’il ne fonctionnait qu’au Pays-Bas.
            Pourriez-vous m’indiquer où trouver ce module actif pour la France?
            Cordialement,
            Nice work.
            I was looking at the MMM-Rain-Forecast module but I understood that it only worked in the Netherlands.
            Could you tell me where to find this active module for France?
            Regards,
              mmourcia @Chris
              @chris hello,
              Thanks for your compliment
              I’m using the FR version.
              Have a look at here https://github.com/tttooommm56/MMM-RainForecast-FR
              	module: 'MMM-RainForecast-FR',
              	position: 'bottom_right',
              	header: 'Prevision pluie',
              		codeInsee: 'xxxxx',
              		showText: true,
              		showGraph: true
              ChrisC 1 Reply Last reply Reply Quote 0
                mmourcia @bhepler
                @bhepler said in Magic mirror first try (France, ~Lille):
                Thank you !
                  mmourcia @cowboysdude
                  @cowboysdude said in Magic mirror first try (France, ~Lille):
                  Thank you too !
                  • L
                    leroyhab
                    Salut,
                    Beau travail.
                    Comment avez-vous choisi le Mirropane™ Chrome Spy 6 mm / SMART MIRROR / SPIONSPIEGEL
                    (70cmx50cm) ?
                      mmourcia @leroyhab
                      @leroyhab said in Magic mirror first try (France, ~Lille):
                      Mirropane
                      Bonjour @leroyhab ,
                      ce miroir est une référence que l’on voit un peu partout et notamment dans ce forum.
                      Le site allemand sur lequel j’ai passé commande peut paraître un peu dur d’accès (enfin avec mes très vieilles notions d’allemand …) mais les gars sont sérieux. Le miroir est arrivé en 15 jours calendaires, très bien emballé.
                      • ChrisC
                        Chris @mmourcia
                        @mmourcia
                        Bonjour,
                        Merci pour le lien, je ne l’avais pas trouvé. J’ai du mal chercher.
                        Cordialement,
                        Thanks for the link, I did not find it. I have trouble searching.
                        Regards,
                        • L
                          leroyhab
                          Salut,
                          Merci pour les réponses.
                          Pourquoi avoir ajouté des enceintes USB, est-ce que l’écran n’était pas équipé de hauts parleurs ?
                            mmourcia @leroyhab
                            bonjour @leroyhab
                            Si si l’écran a des HP (pourris) mais comme je voulais du son en surface du cadre, je n’avais pas envie de démonter et rallonger les HP jusqu’au bord.
                            J’ai choisi une solution plus pratique à mettre en oeuvre.
                            • L
                              leroyhab
                              Ok, bonne idée
                                bolish
                                @mmourcia
                                Beau boulot!
                                Je me tate pour le Chrome Spy 6mm également.
                                L’écran est-il lisible en condition de forte luminosité ou pas du tout?
                                Cdt
                                  mmourcia
                                  Bonjour @bolish !
                                  Si la luminosité est forte alors il faut que je me rapproche du miroir pour bien y voir.
                                  Ca reste lisible mais c’est forcément moins bon que dans la pénombre.
                                  Le mien est dans l’entrée de la maison.
                                  Avec l’éclairage classique à ampoule, aucun problème, avec la luminosité classique, pas de problème.
                                  Lorsque vraiment il y a une éclaircie alors il faut s’approcher un peu plus.
                                  En même temps j’habite dans ch’nord, question lumière naturelle, je suis assez tranquille ;)
                                  Si tu es de passage, tu peux venir constater par toi même !
                                    bolish
                                    @mmourcia
                                    Ca fait loin de chez moi malheureusement (49) mais merci pour la propal’!
                                    Le chrome Spy 6mm semble être le bon compromis d’après tout ce que je lis sachant que comme toi, mon écran sera + petit que le miroir, je ne souhaite pas non plus qu’on voir les bords de la dalle LCD en transparence.
                                    Sur tes photos, j’ai l’impression qu’on ne les distingue pas non plus, ce qui est plutôt positif!
                                    • Atelier-Made-in-iKiA
                                      Atelier-Made-in-iKi
                                      bravo ! superbe travail et merci pour les références sur le miroir en allemagne, pas facile sinon impossible de trouver cela en France
                                      Jean-Philippe
                                      • A
                                        artilari
                                        @mmourcia said in Magic mirror first try (France, ~Lille):
                                        Mirropane Chrome Spy
                                        Are these pilkington mirrors available in the US?
                                          mmourcia @artilari
                                          @artilari said in Magic mirror first try (France, ~Lille):
                                          pilkington
                                          I can’t tell you.
                                          You can ask them if you want.
                                          I’ve bought one with https://www.brigla-shop.de
                                          Let us know
                                            jvanoost
                                            Good job !
                                            Ravi de voir un lillois ici ;) (j’habite pres d’orchies)
                                            chez moi c’est bien plus rudimentaire, mais je pense faire évoluer le cadre et éventuellement le miroir.
                                            mais il faut faire accepter ça à madame…
                                            Bonne journée !
