    How to start
    15 Posts 5 Posters 8.2k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @pukacz
      @pukacz
      1. Install the latest Raspbian WITH desktop environment (but without recommended software) on your SD card from here
      2. Fire up your RasPi 3B+, set up wifi or lan, SSH, and everything you would set up for a running Raspbian system (if you donÄt know why, you will first have to make yourself acquainted with Raspbian itself.
      3. Open the console (directly on the RasPi or via ssh) and follow installation procedure given on github
      1. Enjoy!
      Questions? Get back here :-)
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        pukacz
          pukacz @lavolp3
          @lavolp3 Thank You!
          • G Offline
            ganget
            There is a really nice installation guide from @KirAsh4 that will tell you every thing you need to know!
              pukacz @ganget
              @ganget
              Very good guidance!
                Dodo88
                Hey together :)
                I’m new and could install the software, but i can’t connect to the mirror per localhost for the admin tool.
                Should i install apache2 and put the software to /var/www/html? Or can i run it without @ http://magicmirror?
                Greets :)
                Dodo
                lavolp3L S 2 Replies Last reply Reply Quote 0
                • lavolp3L Offline
                  lavolp3 Module Developer @Dodo88
                  @Dodo88 No, you usually don’t need to do those things, the mirror should run by itself, but you need to use port 8080.
                  Take care of the following:
                  • Go into your config.js and look for the “address” parameter. It needs to be
                    address: "0.0.0.0",
                  • visit your mirror from your browser via: http://localhost:8080
                    If it doesn’t work, try visiting your mirror from another computer using: http://magicmirror:8080
                    -Report if it works :-)
                    Dodo88
                    Hey :)
                    No it doesn’t work :(
                    I get this error by trying “http://192.168.178.33:8080”
                    "Die Website ist nicht erreichbar192.168.178.33 hat die Verbindung abgelehnt.
                    Versuchen Sie Folgendes:
                    Verbindung prüfen
                    ERR_CONNECTION_REFUSED"
                    Should i post my config.js?
                      sdetweil @Dodo88
                      @Dodo88 said in How to start:
                      there is no ‘admin’ tool on MagicMirror
                      also, localhost mean the machine I’m on. so if you are using a windows machine to connect to the mirror, and use localhost, that mean on the windows machine…
                      in addition to what @lavolp3 said, you also need to clear out the ipWhitelist to look like this
                      ipWhitelist: []
                      which means ‘allow anyone to connect’
                      • lavolp3L Offline
                        @Dodo88 This is confusing me now.
                        if you are
                        • EITHER on the machine on which magicmirror is running on, you type:
                        • OR on another machine, then you type:
                          http://192.168.178.33:8080 or http://magicmirror:8080
                        And you need to do what @sdetweil said.
