    How to start
    15 Posts 5 Posters 8.2k Views 5 Watching
      pukacz @lavolp3
      @lavolp3 Thank You!
      • G Offline
        ganget
        There is a really nice installation guide from @KirAsh4 that will tell you every thing you need to know!
          pukacz @ganget
          @ganget
          Very good guidance!
            Dodo88
            Hey together :)
            I’m new and could install the software, but i can’t connect to the mirror per localhost for the admin tool.
            Should i install apache2 and put the software to /var/www/html? Or can i run it without @ http://magicmirror?
            Greets :)
            Dodo
            lavolp3L S 2 Replies Last reply Reply Quote 0
            • lavolp3L Offline
              lavolp3 Module Developer @Dodo88
              @Dodo88 No, you usually don’t need to do those things, the mirror should run by itself, but you need to use port 8080.
              Take care of the following:
              • Go into your config.js and look for the “address” parameter. It needs to be
                address: "0.0.0.0",
              • visit your mirror from your browser via: http://localhost:8080
                If it doesn’t work, try visiting your mirror from another computer using: http://magicmirror:8080
                -Report if it works :-)
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
                Dodo88
                Hey :)
                No it doesn’t work :(
                I get this error by trying “http://192.168.178.33:8080”
                "Die Website ist nicht erreichbar192.168.178.33 hat die Verbindung abgelehnt.
                Versuchen Sie Folgendes:
                Verbindung prüfen
                ERR_CONNECTION_REFUSED"
                Should i post my config.js?
                  sdetweil @Dodo88
                  @Dodo88 said in How to start:
                  there is no ‘admin’ tool on MagicMirror
                  also, localhost mean the machine I’m on. so if you are using a windows machine to connect to the mirror, and use localhost, that mean on the windows machine…
                  in addition to what @lavolp3 said, you also need to clear out the ipWhitelist to look like this
                  ipWhitelist: []
                  which means ‘allow anyone to connect’
                  • lavolp3L Offline
                    @Dodo88 This is confusing me now.
                    if you are
                    • EITHER on the machine on which magicmirror is running on, you type:
                    • OR on another machine, then you type:
                      http://192.168.178.33:8080 or http://magicmirror:8080
                    And you need to do what @sdetweil said.
                      sdetweil @lavolp3
                      @lavolp3 said in How to start:
                      http://magicmirror
                      what is that? none of my machines know where ‘magicmirror’ is located… (I have 6 different instances running, all installed from the same script)
                      • lavolp3L Offline
                        @sdetweil Guess you’re right. Thanks for highlighting. I may have changed the hostname manually at my main mirror
