    How to start
    15 Posts 5 Posters 8.0k Views 5 Watching
      pukacz @ganget
      @ganget
      Very good guidance!
        Dodo88
        Hey together :)
        I’m new and could install the software, but i can’t connect to the mirror per localhost for the admin tool.
        Should i install apache2 and put the software to /var/www/html? Or can i run it without @ http://magicmirror?
        Greets :)
        Dodo
        lavolp3L S 2 Replies Last reply Reply Quote 0
        • lavolp3L Offline
          lavolp3 Module Developer @Dodo88
          @Dodo88 No, you usually don’t need to do those things, the mirror should run by itself, but you need to use port 8080.
          Take care of the following:
          • Go into your config.js and look for the “address” parameter. It needs to be
            address: "0.0.0.0",
          • visit your mirror from your browser via: http://localhost:8080
            If it doesn’t work, try visiting your mirror from another computer using: http://magicmirror:8080
            -Report if it works :-)
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            Dodo88
            Hey :)
            No it doesn’t work :(
            I get this error by trying “http://192.168.178.33:8080”
            "Die Website ist nicht erreichbar192.168.178.33 hat die Verbindung abgelehnt.
            Versuchen Sie Folgendes:
            Verbindung prüfen
            ERR_CONNECTION_REFUSED"
            Should i post my config.js?
              sdetweil @Dodo88
              @Dodo88 said in How to start:
              there is no ‘admin’ tool on MagicMirror
              also, localhost mean the machine I’m on. so if you are using a windows machine to connect to the mirror, and use localhost, that mean on the windows machine…
              in addition to what @lavolp3 said, you also need to clear out the ipWhitelist to look like this
              ipWhitelist: []
              which means ‘allow anyone to connect’
              • lavolp3L Offline
                @Dodo88 This is confusing me now.
                if you are
                • EITHER on the machine on which magicmirror is running on, you type:
                • OR on another machine, then you type:
                  http://192.168.178.33:8080 or http://magicmirror:8080
                And you need to do what @sdetweil said.
                  sdetweil @lavolp3
                  @lavolp3 said in How to start:
                  http://magicmirror
                  what is that? none of my machines know where ‘magicmirror’ is located… (I have 6 different instances running, all installed from the same script)
                  • lavolp3L Offline
                    @sdetweil Guess you’re right. Thanks for highlighting. I may have changed the hostname manually at my main mirror
                      sdetweil @lavolp3
                      @lavolp3 but thank you… this got me thinking about my network… and sure enough the linux boxes added their names to the name server in the router… SO, I can use names instead of numbers…
                      My google wifi router does this better than my old TPLink router did…
                        Dodo88
                        hey, after i cleared the whitelist and reboot the rpi, it works :) Thx you all =)
                        The “Admin Tool” i ment was the module “MMM-Admin-Interface”
                        now booth works :)
                        Thanks a lot!! =)
