    MM2 my first try
    21 Posts 8 Posters 8.4k Views 7 Watching
      seramik
      hi guys
      i just bought my rpi 3B+
      it seems ok for me with raspbian, it worked
      so i launch the automatic install
      then :
      installing dependencies…
      bash: ligne112: npm: commande introuvable
      unable to install dependencies!
      so any advices ? what i’ve done wrong ?
      • G Offline
        ganget @seramik
        @seramik a good question with way too less info to give a good answer. maybe this install guide can help you further!
          seramik
          @ganget said in MM2 my first try:
          thanks for the tutorial
          actually, my problem is on the magicmirror² installation, the step 1 dont run properly
          but i will try again from the start
            Mykle1 Project Sponsor Module Developer @seramik
            @seramik
            This is just a shot in the dark but are node and npm up to date? Older versions of node and npm often cause this.
              seramik
              for the tutorial, it is an very old version, now the first setup is quicker and the ver of MM is very old ( not even mm²)
              so dont advices those kind of thinks …
              i’ve retry for the star and it mades the same trouble
              node version is V8.11.1
              minimum ver required is V5
              i dont know for npm, how to know ?
                @seramik
                node -v
                Edit: npm -v
                  seramik
                  fine, i’ve done correct upgrade and manual install
                  mm² is running
                  i saw him then i stop it with alt key and quit option
                  i’m trying to setup the config.js file
                  and i wonder how i can restart the mm² programm again
                    seramik
                    ok i’ve found that in term , in the correct directory, i write " npm start" and it start
                    i try to understand the config file, i just copied the sample file by changing his name
                    now i will try to change the city for the weather
                      secdude
                      had the same issue with a brand spankin new installation of raspian noobs full and apt-get update/upgrade/dist-upgrade done. freshly set up. the install oneliner failed. only manual setup worked. using a rpi3. maybe there’s a broken dependency somewhere?
                        seramik
                        enought for tonight, i’ve got the weather in my town
                        not so bad for a first day and i dont speak of the weather
