    has anyone used any of the charting tools, like chartjs?
    18 Posts 5 Posters 7.7k Views 5 Watching
      here are some pics of the two charts
      two charts upper right
      two
      two charts closer view
      two closer
      one chart
      one chart
      lavolp3L 1 Reply Last reply Reply Quote 2
      • lavolp3L Offline
        @sdetweil Looking good! How did you realize it? MMM-Chart? Chartjs and your own module?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 using chartjs and my own module. my data is not in JSON format required by MMM-Charts
          here is the chartjs code
          i have an structure, with arrays of points (by the sensor value), javascript Date, and value.
          there are also arrays that contain the axis labels.
          make div for chart
          	var c = document.createElement("div");
          	c.style.width=self.config.width+"px";
            	c.style.height=self.config.height+"px";
          	if(!self.config.stacked)
          	   c.style.display='inline-block';
          	self.wrapper.appendChild(c);
                  canvas= document.createElement("canvas");
           	canvas.id="myChart"+this_pin;
                  c.appendChild(canvas);
          for(var pin_index=0;
                pin_index < self.config.Pins.length;  (how do you do less than in markup?, space after < )
                pin_index++)
          var this_pin=self.config.Pins[pin_index];
                 self.charts[pin_index] = new Chart(canvas, {
                        type: 'line',
                        showLine: true,
                        data: {
                          datasets: [
          		    xAxisID: 'dates',
                              data: self.data[this_pin],
                              fill:true,
                              borderColor: '#2196f3',
             		    backgroundColor: '#2196f3',
                        options:	 {
          			legend: { display: false},
          			tooltips: {
          			    enabled: false,
          			    displayColors: false
          			responsive: false,
          			elements: {
          			    point: { radius: 0 },
          			    line: {
                  		        tension: 0, // disables bezier curves
                          scales: {
                            xAxes: [{
                              type: 'time',
          			distribution: 'linear',
                              scaleLabel: {
                                  display: true,
                                  labelString: self.config.labels[pin_index]+" - last "+self.config.dayrange+" days",
          			fontColor: 'white'
          			gridLines: {
          				display: false,
          				zeroLineColor: '#ffcc33'
            		        time: {
                		              unit: 'minute'
          			bounds: 'data',
                              ticks: {
          			display: false ,
          			maxRotation: 90,
          			source: 'data',
          			maxTicksLimit: self.data[this_pin].length,                    },
                            yAxes: [{
                                  display: true,
                                  scaleLabel: {
                                      display: true,
                                      labelString: self.config.yaxis_legend[pin_index],
          			    fontColor: 'white'
          			gridLines: {
          			   display: true,
          			   color: "#FFFFFF",
          			   zeroLineColor: '#ffcc33',
          			   fontColor: 'white',
                                     scaleFontColor: 'white',
                              ticks: {
          			beginAtZero: true,
          			source: 'data',
                                  min: 0,
          			fontColor: 'white'
          lavolp3L 1 Reply Last reply Reply Quote 1
          • lavolp3L Offline
            @sdetweil Thanks for sharing!!
            I’ll try that out with the rain-forecast module
              sdetweil @lavolp3
              @lavolp3 i have over 4000 measurements in each chart. (3 days, once a minute)
              still pretty reasonable performance.
              update once every 5 minutes, or when come back from sleeping (no updates while MM is asleep).
                I have updated the code now to improve performance…
                • reduce number of data points, by decimation (using 1 point of every 5) to get to 800 points. See info once every 5th minutes, vs once a minute
                • build 800 point data from in memory CSV (api sends back csv data) by looking from NOW (end) til previous (backwards) which reduces the number of lines of data processed from 14000 to 4000 (configurable number of days for chart)
                • create a color gradient table start-end: color, start-end:color2… to draw multiple colors on chart, as part of the data selection in 1 and 2 above… this make the processor O(1) (single pass), instead of O(4)
                performance is much improved…
                prior, 4000 points, elapsed time for 2 charts, 39 seconds. now 3.5 seconds (odroid). pi crashed with 4000 points at 4 minutes elapsed… now just about 4.5 seconds
                  I have no idea what you just said but I upvoted your post anyway. :-)
                  • T Offline
                    Tarun
                    no i never use charting tool what is the function of that tool???
                    • lavolp3L Offline
                      lavolp3 Module Developer @Tarun
                      @tarun well… basically to create charts from data …
                      • lavolp3L Offline
                        I have now used chartjs as well on the MMM-rain-forecast module by @cirdan and SpoturDeal.
                        I like it and there are some plugins to use as well.
                        First results can be achieved very quickly, but if you want to change further specific things, it’s getting difficult with the various objects.
                        @sdetweil do you know of a complete set of options for chartjs? I find the documentation a bit too short and confusing.
                          sdetweil @lavolp3
                          @lavolp3 i do not… there are tons of options, which I guess you would expect.
