    has anyone used any of the charting tools, like chartjs?
    18 Posts 5 Posters 7.0k Views 5 Watching
    • cirdanC Offline
      cirdan
      Mmm rainfc uses jquery sparkline.
      Mmm-rainfc at git
      Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
        sdetweil @cirdan
        @cirdan thanks… trying to stay away from jquery… and the chartjs works fine with 5 or 10 points…
        i have made some progress. the chart appears and has the right axis labels and values…
        the chart itself is drawn wrong… with the jagged line across the x-axis at the right Y-axis height, being drawn vertically on the right edge of the chart, top to bottom…
        cirdanC lavolp3L 2 Replies Last reply Reply Quote 1
        • cirdanC Offline
          cirdan @sdetweil
          @sdetweil not too fond of jquery too. Had to add labels in a creative way. But looks like you are on your way to a chartjs implementation. No experience with that. I would like to see the result though. Perhaps I can rewrite mmm-rainfc. Also when you get stuck, a svg solution is also an possibility…user spotyourdeal did a rewrite of the sparkline into svg for mmm-rainfc
          • lavolp3L Offline
            @sdetweil Well well I was googling “chartjs” about the minute you wrote this down today! Ha! Great.
            I’d like to use it to make some amendments to MMM-rain-forecast and maybe get in my own graph.
            Have you seen MMM-chart, a MM cahrt template, which also seems to have examples of applications like yours.
            I haven’t taken a close look into any of it but I’ll do soon.
            Cheers and good luck!
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              sdetweil @lavolp3
              @lavolp3 said in has anyone used any of the charting tools, like chartjs?:
              MMM-chart,
              thanks… my data does not come back in JSON… but as CSV. with a unix milliseconds timestamp.
              one data set is a float value (could be truncated to int), one is an int.
                ok, well, this was user error…
                while I had an array for time based points, ONE element in the array was JUST a single value.
                this caused the charting tool to act weird…
                fixing the one data point resolved the issue…
                now, I want to change the color of the fill area under certain conditions (low reservoir, or constant running water) to alert about trouble to be resolved…looks like that is some custom extension i have to write…
                  here are some pics of the two charts
                  two charts upper right
                  two
                  two charts closer view
                  two closer
                  one chart
                  one chart
                  lavolp3L 1 Reply Last reply Reply Quote 2
                  • lavolp3L Offline
                    @sdetweil Looking good! How did you realize it? MMM-Chart? Chartjs and your own module?
                      sdetweil @lavolp3
                      @lavolp3 using chartjs and my own module. my data is not in JSON format required by MMM-Charts
                      here is the chartjs code
                      i have an structure, with arrays of points (by the sensor value), javascript Date, and value.
                      there are also arrays that contain the axis labels.
                      make div for chart
                      	var c = document.createElement("div");
                      	c.style.width=self.config.width+"px";
                        	c.style.height=self.config.height+"px";
                      	if(!self.config.stacked)
                      	   c.style.display='inline-block';
                      	self.wrapper.appendChild(c);
                              canvas= document.createElement("canvas");
                       	canvas.id="myChart"+this_pin;
                              c.appendChild(canvas);
                      for(var pin_index=0;
                            pin_index < self.config.Pins.length;  (how do you do less than in markup?, space after < )
                            pin_index++)
                      var this_pin=self.config.Pins[pin_index];
                             self.charts[pin_index] = new Chart(canvas, {
                                    type: 'line',
                                    showLine: true,
                                    data: {
                                      datasets: [
                      		    xAxisID: 'dates',
                                          data: self.data[this_pin],
                                          fill:true,
                                          borderColor: '#2196f3',
                         		    backgroundColor: '#2196f3',
                                    options:	 {
                      			legend: { display: false},
                      			tooltips: {
                      			    enabled: false,
                      			    displayColors: false
                      			responsive: false,
                      			elements: {
                      			    point: { radius: 0 },
                      			    line: {
                              		        tension: 0, // disables bezier curves
                                      scales: {
                                        xAxes: [{
                                          type: 'time',
                      			distribution: 'linear',
                                          scaleLabel: {
                                              display: true,
                                              labelString: self.config.labels[pin_index]+" - last "+self.config.dayrange+" days",
                      			fontColor: 'white'
                      			gridLines: {
                      				display: false,
                      				zeroLineColor: '#ffcc33'
                        		        time: {
                            		              unit: 'minute'
                      			bounds: 'data',
                                          ticks: {
                      			display: false ,
                      			maxRotation: 90,
                      			source: 'data',
                      			maxTicksLimit: self.data[this_pin].length,                    },
                                        yAxes: [{
                                              display: true,
                                              scaleLabel: {
                                                  display: true,
                                                  labelString: self.config.yaxis_legend[pin_index],
                      			    fontColor: 'white'
                      			gridLines: {
                      			   display: true,
                      			   color: "#FFFFFF",
                      			   zeroLineColor: '#ffcc33',
                      			   fontColor: 'white',
                                                 scaleFontColor: 'white',
                                          ticks: {
                      			beginAtZero: true,
                      			source: 'data',
                                              min: 0,
                      			fontColor: 'white'
                      lavolp3L 1 Reply Last reply Reply Quote 1
                      • lavolp3L Offline
                        @sdetweil Thanks for sharing!!
                        I’ll try that out with the rain-forecast module
