Solved PM2 does not start the Magic Mirror
@lavolp3 The Mirror does start if i start it manually.
this is the whole error log:
Error: ENOENT: no such file or directory, open 'package.json' at Object.fs.openSync (fs.js:646:18) at Object.fs.readFileSync (fs.js:551:33) at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:32) at Module._compile (module.js:652:30) at Object.Module._extensions..js (module.js:663:10) at Module.load (module.js:565:32) at tryModuleLoad (module.js:505:12) at Function.Module._load (module.js:497:3) at Module.require (module.js:596:17) at require (internal/module.js:11:18)
and this is the log out:
> magicmirror@2.6.0 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.6.0 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar No helper found for module: compliments. No helper found for module: currentweather. No helper found for module: weatherforecast. Initializing new module helper ... Module helper loaded: newsfeed All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Sockets connected & modules started ... Launching application. Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000 Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 Shutting down server... Stopping module helper: updatenotification Stopping module helper: calendar Stopping module helper: newsfeed
These are the logs of pm2.
The Mirror does not start if i start it from pm2.thanks for helping! :)
I have the same problem.
I installed a fresh MM with pm2. The MM started. But after a reboot the MM does not start automatically.
Unfortunately I have no idea.
It would be grateful, if someone could help me.
Thank you in advance
I would suggest to both of you to follow the complete guide setting up pm2 and the autostart again. It doesn’t take long.
Besides that, what does
pm2 status
give you after reboot?
pm2 status is
pi@raspberrypi:~ $ pm2 status │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │ MagicMirror │ 0 │ 2.6.0 │ fork │ online │ 799 │ 0% │ 16.8 MB │ Use `pm2 show <id|name>` to get more details about an app
and in pm2 log I get this every two seconds
pi@raspberrypi:~/.pm2 $ tail -f pm2.log 2019-02-15T15:36:47: PM2 log: App [MagicMirror:0] online 2019-02-15T15:36:48: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
I tried the complete guide with creating an .sh-File and so on. But unfortenately with the same effect.
@klinge can you first do
pm2 stop all
and then
cd ~/MagicMirror npm start dev
Maybe you can see what happens there.
It seems that pm2 is running the magicmirror start script but MagicMirror won’t start -
@lavolp3 starting it manually does work. but with PM2 not.
Thank you for your help.
But suddenly a miracle happened.
Tomorrow morning I switched on my monitor and the MM runs. And I did not do anything. And I really haven´t a intelligent reason.
Now, when I reboot the Raspberry, the MM starts automatically.
Thank you for your time.
@klinge said in PM2 does not start the Magic Mirror:
MMM-TimeMachine? ;-)
I’m glad you got it working correctly. :thumbsup:
@klinge Yeah I hacked into your RasPi from here and fixed it … I will have done it next Thursday when I will have had some time.
Better change your password from standard “raspberry”.
yaaaawwwn -
Hey Guys!
it works now!
i did it as described with the mm script here: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirrorthank you for all your replies!
Regards
Dario
