    PM2 does not start the Magic Mirror
    pm2errorenoent
    15 Posts 5 Posters 20.2k Views 4 Watching
    • bheplerB Offline
      bhepler Module Developer @DarioCas
      @dariocas - First, check to see if anything pm2 related still exists on your Pi: type pm2 status all. If you get a table in reply, then pm2 is there, you just need to configure it.
      If you get “command not found” then you’ll need to install pm2 manually: npm install pm2 -g. Once that finishes, you’ll want to initalize pm2 with pm2 startup. It will do a mess of things and at the end it will output a command for you to enter. This is important! You need to copy that command from the output and paste it into the command line. That will enable pm2 to start when the Pi reboots.
      Give it a go and let us know what you find.
      • lavolp3L Offline
        lavolp3 Module Developer
        Dario, what was the command that created this error message.
        You need to give us a bit more information
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          DarioCas @lavolp3
          @lavolp3 this was in the LOG of pm2:
          Error ENOENT no such file or directory, open ‘packages.json’
          I think the command was open packages.json
          • lavolp3L Offline
            lavolp3 Module Developer @DarioCas
            @dariocas So the error message was created on startup of the mirror? And the mirror did not start?
            Can you start the mirror without pm2?
            npm start dev
            Can you post the complete log of the process?
            Can you post what is inside the file that was created for the pm2 process?
            Still not enough information to help, sorry.
              DarioCas @lavolp3
              @lavolp3 The Mirror does start if i start it manually.
              this is the whole error log:
              Error: ENOENT: no such file or directory, open 'package.json'
                  at Object.fs.openSync (fs.js:646:18)
                  at Object.fs.readFileSync (fs.js:551:33)
                  at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:32)
                  at Module._compile (module.js:652:30)
                  at Object.Module._extensions..js (module.js:663:10)
                  at Module.load (module.js:565:32)
                  at tryModuleLoad (module.js:505:12)
                  at Function.Module._load (module.js:497:3)
                  at Module.require (module.js:596:17)
                  at require (internal/module.js:11:18)
              and this is the log out:
              > magicmirror@2.6.0 start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.6.0
              Loading config ...
              Loading module helpers ...
              All module helpers loaded.
              Server started ...
              Starting module: newsfeed
              Launching application.
              Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
              Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              Shutting down server...
              Stopping module helper: updatenotification
              Stopping module helper: calendar
              Stopping module helper: newsfeed
              These are the logs of pm2.
              The Mirror does not start if i start it from pm2.
              thanks for helping! :)
              1 Reply Last reply Reply Quote -1
              • K Offline
                Klinge
                I have the same problem.
                I installed a fresh MM with pm2. The MM started. But after a reboot the MM does not start automatically.
                Unfortunately I have no idea.
                It would be grateful, if someone could help me.
                Thank you in advance
                • lavolp3L Offline
                  I would suggest to both of you to follow the complete guide setting up pm2 and the autostart again. It doesn’t take long.
                  Besides that, what does
                  pm2 status
                  give you after reboot?
                  • K Offline
                    Klinge
                    pm2 status is
                    pi@raspberrypi:~ $ pm2 status
                    │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory
                    │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 799 │ 0%     │ 16.8 MB   │
                     Use `pm2 show <id|name>` to get more details about an app
                    and in pm2 log I get this every two seconds
                    pi@raspberrypi:~/.pm2 $ tail -f pm2.log
                    2019-02-15T15:36:47: PM2 log: App [MagicMirror:0] online
                    2019-02-15T15:36:48: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                    I tried the complete guide with creating an .sh-File and so on. But unfortenately with the same effect.
                    lavolp3L 1 Reply Last reply Reply Quote 1
                    • lavolp3L Offline
                      lavolp3 Module Developer @Klinge
                      @klinge can you first do
                      pm2 stop all
                      and then
                      npm start dev
                      Maybe you can see what happens there.
                      It seems that pm2 is running the magicmirror start script but MagicMirror won’t start
                        DarioCas @lavolp3
                        @lavolp3 starting it manually does work. but with PM2 not.
                        • K Offline
                          Klinge
                          Thank you for your help.
                          But suddenly a miracle happened.
                          Tomorrow morning I switched on my monitor and the MM runs. And I did not do anything. And I really haven´t a intelligent reason.
                          Now, when I reboot the Raspberry, the MM starts automatically.
                          Thank you for your time.
                          Mykle1M lavolp3L 2 Replies Last reply Reply Quote 2
                            Mykle1 Project Sponsor Module Developer @Klinge
                            @klinge said in PM2 does not start the Magic Mirror:
                            MMM-TimeMachine? ;-)
                            I’m glad you got it working correctly. :thumbsup:
                            • lavolp3L Offline
                              @klinge Yeah I hacked into your RasPi from here and fixed it … I will have done it next Thursday when I will have had some time.
                              Better change your password from standard “raspberry”.
                              yaaaawwwn
                                DarioCas
                                Hey Guys!
                                it works now!
                                i did it as described with the mm script here: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                thank you for all your replies!
                                Regards
                                Dario
