Google-route Citys disappear changing height/width
10 Posts 2 Posters 2.2k Views 2 Watching
  • T Offline
    thedk
    Hey Guys,
    colud somebody explain to me why the citys are disappearing when i change the width or the height?
    When they are on 250 px erverything is normal.
    • T Offline
      thedk
      Tried to change the size of the modul in der custom.css. When i do that, the modul just moves to down or to side, out of the display.
      Nobody with the same issue?
          Changing the size of the module might not be enough. You might have to change the size of the map as well. Use the inspector that comes up when you start MM with npm start dev to figure out what elements you need to target in your CSS.
          • T Offline
            thedk
            Could you explain me how to do this?
            J 1 Reply Last reply Feb 17, 2019, 5:37 PM Reply Quote 0
              j.e.f.f Project Sponsor Module Developer @thedk
              @thedk start by reading through this thread:
              https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
              It goes through how to use the dev tools console to inspect HTML elements for the CSS is use
              If you still have questions, post back here and I’ll help as best I can.
              • T Offline
                thedk
                Thanks for your help.
                So i have to change the size of the region where the modul is i guess.
                J 1 Reply Last reply Feb 17, 2019, 5:58 PM Reply Quote 0
                  @thedk and maybe the region where the map is displayed too. Very possiblenit is sized independently of the outer module wrapper. I can’t say for sure since I haven’t used the module but it would be where I would start looking if I wanted to resize it.
                  • T Offline
                    thedk
                    tested it and i dont know why, but it doesnt work.
                    Thats my custom.css
                     body {
                    .normal {
                      color: #fff;
                    .region.top.right,
                    .region.top.left,
                    .region.top.center {
                      top: 80%;
                    .region.bottom.right,
                    .region.bottom.center,
                    .region.bottom.left {
                      bottom: 80%;
                    • T Offline
                      thedk
                      Also with max-width and max-height the map doesnt get smaller, it just moves out of the Display.
