    NFL Score Module
    95 Posts 20 Posters 136.0k Views 25 Watching
    • strawberry 3.141S
      I will create a module next week, just tell me in a personal message what should be displayed in the module (have no clue about baseball and what data can be interesting) as its not related to the nfl module
      C 1 Reply Last reply
      • strawberry 3.141S
        due to the different timezone, it would be nice if some of you could test my alpha version of live match detecting on the next matchday, by doing
        git fetch
        git checkout feature/live-matches
        start your mirror and report here how it goes, it should detect live matches automatically and while at least one match is running it fetches every minute for new data, otherwise it will stay by the standard 3hours interval
        it’s not tested yet, but if it works you should see that the time of a quarter get’s updated and the score as well. it will also show which team is in ball possession and if the team is entering the redzone it will start to flash the indicator. if something is not working pls provide the errors from the terminal and the electron console (cmd+shift+I)
        • cowboysdudeC
          cowboysdude Module Developer @strawberry 3.141
          @strawberry-3.141 Let you know this Wed and Thurs… :) Thank you!!!
          • cowboysdudeC
            It’s working great!! Time/Quarter and what team has the ball and when they’re in the red zone… Great job!
            • strawberry 3.141S
              after no issues were found on the last pre-season matchday there is a new release
              Changelog:
              • indicator for ball possession
              • indicator for redzone
              • auto detecting live matches and fetching new data every minute, while at least on match is live
              • new config option focus_on to choose which matches should appear on the mirror
              Preview
              [card:fewieden/MMM-NFL]
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                after an issue on github i made a bugfix on a seperate branch so people can test if this will work for everyone
                cd ~/MagicMirror/modules/MMM-NFL
                git fetch
                git checkout bugfix/time-conversion
                npm install
                start your mirror and see if the match start datetime is correct for your timezone
                • strawberry 3.141S
                  The changes are now merged to master branch
                  To update do the following
                  git pull
                  npm install
                  If you tested the bugfix branch you have to do the following
                  git checkout master
                  git pull
                  • strawberry 3.141S
                    I want to announce, that there will come statistics in place the next days
                    alt text
                    • cowboysdudeC
                      That’s really AWESOME! Thank you!!!
                      • K
                        kwaeksler
                        Your Module looks very awesome!!
                        Do you think you could create a step by step instructions for the installation?
                        Because for me it isnt working atm and i dont know why…
                        strawberry 3.141S K 2 Replies Last reply
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @kwaeksler
                          @kwaeksler https://github.com/fewieden/MMM-NFL#installation
                          any errors in the console?
                          did you run npm install?
                          in the config { module: 'MMM-NFL', position: 'top_right'}
                          • K
                            kwaeksler @kwaeksler
                            @kwaeksler said in NFL Score Module:
                            Was probably my fault. Apparently I had an incorrect configuration of the MagicMirror.
                            I had one more error with a default module so i’ve reinstalled my MagicMirror.
                            After the installation and configuration of the MM the NFL Module works very fine.
                            So sorry for trouble and a great thank you for support @strawberry-3-141
                            Love your Module!
                            Reply Quote 2
                              daveyg_71
                              I love this module. It looks awesome.
                              I am trying to remove the TV column, and it doesn’t seem to be having any effect. I set network to false.
                                                  module: 'MMM-NFL',
                                                  position: 'top_right',
                                                          colored: 'false',
                                                          network: 'false',
                                                          reloadInterval: 900000,
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @daveyg_71
                                @daveyg_71 you need to remove the quotes, otherwise the boolean is a string and will represent true
                                    colored: false,
                                    network: false,
                                  daveyg_71
                                  That worked to remove the network column but to have the colored logos show up I had to have the quotes. This is how I have it set and I have colored logos and no TV column.
                                                      module: 'MMM-NFL',
                                                              colored: 'false',
                                                              network: false,
                                  • strawberry 3.141S
                                    @daveyg_71 well when you want to have the color the right way to go is this colored: true
                                    Reply Quote 2
                                      Shawnsully
                                      For the life of me, i cant figure this out how to get this Module to work. I have followed the instructions to a T. However I keep getting the generic “please add a config” when I start up the mirror.
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @Shawnsully
                                        @Shawnsully can you post your config file
                                          Shawnsully @strawberry 3.141
                                          @strawberry-3.141 Thank you so much for your help
                                          module: ‘MMM-NFL’,
                                          position: ‘bottom_left’,
                                          colored: true,
                                          network: false,
                                          reloadinterval: 900000,
                                          cowboysdudeC B 2 Replies Last reply
                                          • cowboysdudeC
                                            cowboysdude Module Developer @Shawnsully
                                            @Shawnsully
                                            @Shawnsully said in NFL Score Module:
                                            module: ‘MMM-NFL’,
                                            colored: true,
                                            network: false,
                                            Your missing something… copy this and try it…
                                            module: ‘MMM-NFL’,
                                            colored: true,
                                            network: false,
                                            • 2 / 5
