    NFL Score Module
    95 Posts 20 Posters 134.2k Views 25 Watching
    • strawberry 3.141S Offline
      The changes are now merged to master branch
      To update do the following
      cd ~/MagicMirror/modules/MMM-NFL
      git pull
      npm install
      If you tested the bugfix branch you have to do the following
      git checkout master
      git pull
        I want to announce, that there will come statistics in place the next days
        alt text
        • cowboysdudeC Offline
          That’s really AWESOME! Thank you!!!
          • K Offline
            kwaeksler
            Your Module looks very awesome!!
            Do you think you could create a step by step instructions for the installation?
            Because for me it isnt working atm and i dont know why…
            strawberry 3.141S K 2 Replies Last reply Reply Quote 0
              strawberry 3.141 Project Sponsor Module Developer @kwaeksler
              @kwaeksler https://github.com/fewieden/MMM-NFL#installation
              any errors in the console?
              did you run npm install?
              in the config { module: 'MMM-NFL', position: 'top_right'}
              • K Offline
                kwaeksler @kwaeksler
                @kwaeksler said in NFL Score Module:
                Was probably my fault. Apparently I had an incorrect configuration of the MagicMirror.
                I had one more error with a default module so i’ve reinstalled my MagicMirror.
                After the installation and configuration of the MM the NFL Module works very fine.
                So sorry for trouble and a great thank you for support @strawberry-3-141
                Love your Module!
                  daveyg_71
                  I love this module. It looks awesome.
                  I am trying to remove the TV column, and it doesn’t seem to be having any effect. I set network to false.
                                      module: 'MMM-NFL',
                                      position: 'top_right',
                                              colored: 'false',
                                              network: 'false',
                                              reloadInterval: 900000,
                    strawberry 3.141 Project Sponsor Module Developer @daveyg_71
                    @daveyg_71 you need to remove the quotes, otherwise the boolean is a string and will represent true
                        colored: false,
                        network: false,
                      daveyg_71
                      That worked to remove the network column but to have the colored logos show up I had to have the quotes. This is how I have it set and I have colored logos and no TV column.
                                          module: 'MMM-NFL',
                                                  colored: 'false',
                                                  network: false,
                        @daveyg_71 well when you want to have the color the right way to go is this colored: true
                          Shawnsully
                          For the life of me, i cant figure this out how to get this Module to work. I have followed the instructions to a T. However I keep getting the generic “please add a config” when I start up the mirror.
                            strawberry 3.141 Project Sponsor Module Developer @Shawnsully
                            @Shawnsully can you post your config file
                              Shawnsully @strawberry 3.141
                              @strawberry-3.141 Thank you so much for your help
                              module: ‘MMM-NFL’,
                              position: ‘bottom_left’,
                              colored: true,
                              network: false,
                              reloadinterval: 900000,
                              cowboysdudeC B 2 Replies Last reply Reply Quote 0
                                cowboysdude Module Developer @Shawnsully
                                @Shawnsully
                                @Shawnsully said in NFL Score Module:
                                module: ‘MMM-NFL’,
                                colored: true,
                                network: false,
                                Your missing something… copy this and try it…
                                module: ‘MMM-NFL’,
                                colored: true,
                                network: false,
                                  Shawnsully @cowboysdude
                                  @cowboysdude Again, thank you for your assistance. I still get the generic “Please add config” error.
                                    OK well I’d see to your entire config … private msg me with your entire config.js file… so I can take a look at it.
                                      [card:fewieden/MMM-NFL]
                                      Changelog:
                                      Removed network column due to it’s not longer provided through the API
                                      Implemented voice commands to show passing, rushing, receiving, tackles, sacks and interceptions statistics
                                      Color and Logo type are also changeable through voice commands on the fly
                                      alt text
                                        Changelog:
                                        • Handling Bye Week for focus_on teams
                                        alt text
                                        strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                          bhepler Module Developer @Shawnsully
                                          @Shawnsully Double-check your commas and curly braces, specifically at the beginning of your module entry. You have:
                                               module: 'MMM-NFL',
                                          You probably want:
                                               module: 'MMM-NFL',
                                            strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                                            Changelog:
                                            • possible fix for starting times of matches in london
                                            O 1 Reply Last reply Reply Quote 1
                                            • 2 / 5
