    NFL Score Module
    95 Posts 20 Posters 137.4k Views 25 Watching
    • cowboysdudeC
      It’s working great!! Time/Quarter and what team has the ball and when they’re in the red zone… Great job!
      • strawberry 3.141S
        after no issues were found on the last pre-season matchday there is a new release
        Changelog:
        • indicator for ball possession
        • indicator for redzone
        • auto detecting live matches and fetching new data every minute, while at least on match is live
        • new config option focus_on to choose which matches should appear on the mirror
        Preview
        [card:fewieden/MMM-NFL]
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
          after an issue on github i made a bugfix on a seperate branch so people can test if this will work for everyone
          cd ~/MagicMirror/modules/MMM-NFL
          git fetch
          git checkout bugfix/time-conversion
          npm install
          start your mirror and see if the match start datetime is correct for your timezone
          • strawberry 3.141S
            The changes are now merged to master branch
            To update do the following
            git pull
            npm install
            If you tested the bugfix branch you have to do the following
            git checkout master
            git pull
            • strawberry 3.141S
              I want to announce, that there will come statistics in place the next days
              alt text
              • cowboysdudeC
                That’s really AWESOME! Thank you!!!
                • K
                  kwaeksler
                  Your Module looks very awesome!!
                  Do you think you could create a step by step instructions for the installation?
                  Because for me it isnt working atm and i dont know why…
                  strawberry 3.141S K 2 Replies Last reply
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @kwaeksler
                    @kwaeksler https://github.com/fewieden/MMM-NFL#installation
                    any errors in the console?
                    did you run npm install?
                    in the config { module: 'MMM-NFL', position: 'top_right'}
                    • K
                      kwaeksler @kwaeksler
                      @kwaeksler said in NFL Score Module:
                      Was probably my fault. Apparently I had an incorrect configuration of the MagicMirror.
                      I had one more error with a default module so i’ve reinstalled my MagicMirror.
                      After the installation and configuration of the MM the NFL Module works very fine.
                      So sorry for trouble and a great thank you for support @strawberry-3-141
                      Love your Module!
                      Reply Quote 2
                        daveyg_71
                        I love this module. It looks awesome.
                        I am trying to remove the TV column, and it doesn’t seem to be having any effect. I set network to false.
                                            module: 'MMM-NFL',
                                            position: 'top_right',
                                                    colored: 'false',
                                                    network: 'false',
                                                    reloadInterval: 900000,
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @daveyg_71
                          @daveyg_71 you need to remove the quotes, otherwise the boolean is a string and will represent true
                              colored: false,
                              network: false,
                            daveyg_71
                            That worked to remove the network column but to have the colored logos show up I had to have the quotes. This is how I have it set and I have colored logos and no TV column.
                                                module: 'MMM-NFL',
                                                        colored: 'false',
                                                        network: false,
                            • strawberry 3.141S
                              @daveyg_71 well when you want to have the color the right way to go is this colored: true
                              Reply Quote 2
                                Shawnsully
                                For the life of me, i cant figure this out how to get this Module to work. I have followed the instructions to a T. However I keep getting the generic “please add a config” when I start up the mirror.
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Shawnsully
                                  @Shawnsully can you post your config file
                                    Shawnsully @strawberry 3.141
                                    @strawberry-3.141 Thank you so much for your help
                                    module: ‘MMM-NFL’,
                                    position: ‘bottom_left’,
                                    colored: true,
                                    network: false,
                                    reloadinterval: 900000,
                                    cowboysdudeC bheplerB 2 Replies Last reply
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Shawnsully
                                      @Shawnsully
                                      @Shawnsully said in NFL Score Module:
                                      module: ‘MMM-NFL’,
                                      colored: true,
                                      network: false,
                                      Your missing something… copy this and try it…
                                      module: ‘MMM-NFL’,
                                      colored: true,
                                      network: false,
                                        Shawnsully @cowboysdude
                                        @cowboysdude Again, thank you for your assistance. I still get the generic “Please add config” error.
                                        • cowboysdudeC
                                          OK well I’d see to your entire config … private msg me with your entire config.js file… so I can take a look at it.
                                          • strawberry 3.141S
                                            Changelog:
                                            Removed network column due to it’s not longer provided through the API
                                            Implemented voice commands to show passing, rushing, receiving, tackles, sacks and interceptions statistics
                                            Color and Logo type are also changeable through voice commands on the fly
                                            alt text
                                            • 2 / 5
