    Autostart MM after reboot doesn't work
    6 Posts 3 Posters 2.5k Views 2 Watching
    • ferra1980F
      ferra1980
      I have made a clean manual install on a PI2, everythings works fine, but after a reboot MM doesn’t start by himself. I have made the changes indicated at Auto Start MM and the MM restart automatically if I manually close it but doesn’t do it after a reboot.
      Any hint?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @ferra1980
        @ferra1980
        If MM reboots automatically after you manually quit then auto-reboot is functioning properly. On reboot of the system it does take time for MM to reboot. Please wait at least a minute after you see the desktop.
        ferra1980F 1 Reply Last reply
        • ChrisC
          Chris
          I had the same problem with pm2.
          Indeed, I reinstalled several times, and each time everything went well. I created my mm.sh file and saved it.
          However, each time I restarted my PI, it was not taken into account.
          I solved this problem by following this thread:
          PM2 MM2 Not starting on start up
          especially the shbatm solution as the last message.
          By the way thank you to him.
          Regards,
          • ferra1980F
            ferra1980 @Mykle1
            @mykle1 I tried to wait, but it is on for 1 hour and I only see the desktop, I think something does not work
            • ferra1980F
              ferra1980 @Chris
              @chris I’ll try your call! Thanks
              • Mykle1M
                @ferra1980 said in Autostart MM after reboot doesn't work:
                Ok, waiting an hour is quite long enough. I hope you have success following the link that chris gave you. :thumbsup:
