    Monitor for MagicMirror, 22-26 inch
    15 Posts 7 Posters 12.6k Views 5 Watching
      j.e.f.f Project Sponsor Module Developer @roxx
      @roxx really any monitor will do, and I don’t really know anything about the models you’ve listed. But things to look for are as follows:
      • Brightness: two-way glass, by its nature steals light so that it can reflect light as well as transmit it. Brighter monitors are better for this project. If your budget allows, OLED is the best choice since it offers great brightness and no backlight glow.
      • overall thickness. While it’s possible to strip the monitor down to the bare chassis, if it’s thinner to start with then you’re overall mirror will be thinner.
      • how the HDMI connects makes a huge difference. You want it to connect flat instead of sticking out the back. I went with a 32” TV for the size, and bought one from Samsung because my cousin used to work there and I got a discount. The drawback was the HDMI plugged in the back such that it sticks out at a 90 degree angle. I was able to find a 90 degree connector to minimize this but the result was an extra cm or so added to the total thickness of my mirror.
      K 1 Reply Last reply Reply Quote 1
        roxx
        Thanks for your inputs, friends… I will go to shops and find a monitor to buy hand to hand, on the internet i am just selecting which to buy, least i prefer to buy online, but doable…
        Thickness wont be a problem i guess because i have already thought to make a thick frame, i have mounted cooling fans from my PC on my Rpi3B+ so its around 12x12x15cm… Will post pics once its fully built. Also the AC/DC adapters for fan will occupy space!
        Only a biker knows why dogs stick their head outside the window of a moving vehicle!!
        • BKeyportB Offline
          BKeyport Module Developer
          I grabbed an ACER KA270H Abix - because it’s thin and has very little face plastic - so I don’t have to take it apart to use it. Ended up taking it apart anyway to see if the name badge bar is removable to make no face plastic, and it is… Pulled it off, black taped over the metal piece it hid, and have the button bar ready to move to an edge.
            roxx @BKeyport
            @bkeyport said in Monitor for MagicMirror, 22-26 inch:
            … does it have inbuilt speakers? I guess “abix” means without speakers… i am not sure…
            • BKeyportB Offline
              It does not, I didn’t care if I had speakers or not, as I’m running a silent setup.
                roxx
                Hello friends… finally i have decided to buy “BenQ GW2470ML” it has inbuilt speakers, there is another variant also without speakers. I will be buying it in 2 or 3 days. I hope buying this monitor is worth it…
                BenQ GW2470ML
                Amazon GW2470ML
                Any last moment questions or advice!?
                  bhepler Module Developer
                  That looks like it will do just fine.
                  • BKeyportB Offline
                    Yep. looks good to me.
                      roxx @BKeyport
                      Hello friends, previously selected monitor to buy was 24inch BenQ GW2470ML available on Amazon GW2470ML
                      But, i came across another monitor which are 27 inch and thought i could go for a bigger screen… So i request you friends to take a look and suggest me which is worth buying… These are the other two monitors…
                      Acer S271 HLG 27" on amazon also see details on acer
                      BenQ 27" on amazon also see details on benq
                      How are these 27inch monitors? Should i buy previously selected 24in or 27in monitors… I think bigger is better if its worth to buy for magic mirror…i am tempted to buy the bigger screen monitor… Suggest me one out of these…
                      • K Offline
                        klimbo @j.e.f.f
                        @j-e-f-f said in Monitor for MagicMirror, 22-26 inch:
                        thank you for all this informations bro
                          roxx
                          thanks friends, finally i am buying BenQ 27inch, details on BenQ.com … i am buying it from local store, will get it on monday, 3rd march.
                          lets see then :slightly_smiling_face:
                            cubesmi @roxx
                            Hi @roxx
                            Did you get your EW2775ZH?
                            With its contrast, brightness and thickness it seems the best option for me as well at this moment. What is the thickness after removing it from its case?
                              roxx @cubesmi
                              @cubesmi said in Monitor for MagicMirror, 22-26 inch:
                              Hi @roxx
                              Hi, i have removed the case yesterday… Will post details and pics soon… I need some time…
