Unsolved MMM-Assistantmk2 and MMM-Hotword not picking up
@sdetweil I’m not using MMM-Voice, I’m using MMM-Assistantmk2 and MMM-Hotword, hotword pics up the word to wake the assistant and assistant takes care of the rest. I’ve been able to talk to the assistant but hotword doesn’t wake when I say the wakeword.
@ejay-ibm here is my magicmirror config file:
var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "updatenotification", position: "top_bar" }, { module: "MMM-AssistantMk2", position: "top_bar", config: { record: { recordProgram : "arecord", device : "plughw:1, 0", }, notifications: { ASSISTANT_ACTIVATED: "HOTWORD_PAUSE", ASSISTANT_DEACTIVATED: "HOTWORD_RESUME", }, } }, { module: "MMM-Hotword", config: { record: { recordProgram : "arecord", device : "plughw:1, 0", }, autostart:true, onDetected: { notification: function (payload) { return "ASSISTANT_ACTIVATE" }, payload: function (payload){ return { profile: payload.hotword } } }, }, }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "Dubuque", locationID: "4854529", //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city appid: "6730254e02c0f50e5d951db321f6fa33" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Dubuque", locationID: "4854529", //ID from https://openweathermap.org/city appid: "6730254e02c0f50e5d951db321f6fa33" } }, { module: "MMM-EARTH", position: "bottom_right", config: { mode: "Natural", rotateInterval: 15000, MaxWidth: "30%", MaxHeight: "30%", } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, { module: 'MMM-ShairportMetadata', position: 'bottom_left', config: { metadataPipe: "/tmp/shairport-sync-metadata", // location of pipe with shairport-sync metadata alignment: "center", // Possible values [left|right|center]. Default: center } }, ] };
here is the output for aplay -l:
pi@raspberrypi:~ $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA] Subdevices: 7/7 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI] Subdevices: 1/1 Subdevice #0: subdevice #0
I do use PulseAudio because i use the PS3 eye mic, which uses a mic array that alsamixer doesn’t like, but it works when i talk to the assistant, Hotword just doesn’t hear my wakewords.
Here is the output for arecord -lpi@raspberrypi:~ $ arecord -l **** List of CAPTURE Hardware Devices **** card 1: CameraB409241 [USB Camera-B4.09.24.1], device 0: USB Audio [USB Audio] Subdevices: 1/1 Subdevice #0: subdevice #0
It seems to work whether i use “plughw: 0” and “plughw: 0, 1”.
@jmartin1009 I would remove the space in the device name
"plughw: 0,1"
I just installed MMM-Hotword, and used this config
{ module: "MMM-Hotword", config: { autostart:true, autorestart: true }
and it works fine…
i did have a little snowboy rebuild work to do but documented in the hotword install doc… -
@sdetweil I can try removing the space and hope to works, and I had to do the snowboy rebuild already as it said I had an error when I tried to start magicmirror, so that should be okay, so I’ll try deleting the space and if it doesn’t work I will try to rebuild snowboy and try again and I’ll get back to you. Thanks!!
@sdetweil is that your config for magicmirror or in the config file or hotword?
@sdetweil I tried getting rid of the space, I tried adding autorestart=true on both configs, and still no luck :/
@jmartin1009 just the config for hotword.
I agree with Sam :
You need to remove the space at both places.
1st in MMM-AssistantMk2module: "MMM-AssistantMk2", position: "top_bar", config: { record: { recordProgram : "arecord", device : "plughw:1,0",
And as well in
module: "MMM-Hotword", config: { record: { recordProgram : "arecord", device : "plughw:1,0",
If that still doesn’t work try just :
plughw:1As well you should check in the audio properties that your mic have enough gain.
you can check this by typing
alsamixer
in command linehope this helps
Ejay
