    Button
    23 Posts 9 Posters 25.8k Views 5 Watching
    • K
      KirAsh4 Moderator
      Yeah, that’s a floating button. You need a pull-down on it, a known state, so the rpi can detect a change. You can either do that in software with RPi.GPIO and configuring it as such:
      GPIO.setup(PIN, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
      Or through hardware:
      https://www.cl.cam.ac.uk/projects/raspberrypi/tutorials/robot/buttons_and_switches/
        dicker182
        Okay, now I have a script button.py which starts with rc.local after boot.
        import RPi.GPIO as GPIO
        import time
        GPIO.setmode(GPIO.BCM)
        GPIO.setup(9, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
        GPIO.cleanup()           # clean up GPIO on normal exit
        But it´s also not working. Did I miss something?
        • K
          KirAsh4 Moderator
          Different permissions. Your rc.local runs with system privileges, however the MM² task runs as the pi user. You need to have those GPIO setting in the script that the pi user runs.
            dicker182
            Okay thanks, the script now starting as user pi.
            Other question, has my button.py script to run in a loop?
            EDIT: Okay the message “button pressed” are coming when I turn the floor lights on 0o?
            • K
              KirAsh4 Moderator
              1. Take out that 'GPIO.cleanup()' call that you have. That resets everything you just did above it.
              2. Button getting triggered because you turning on the floor (?) lights is because that button is still floating, see #1 above.
              3. I’m assuming the rpi isn’t on the same circuit as the floor (??) lights, a voltage difference could also falsely trigger the button.
                dicker182
                Yes it seems it is on the same circuit. The button is pressed when the light goes on and when the light goes off… :D unbelievable
                C 1 Reply Last reply
                • K
                  KirAsh4 Moderator
                  So your rpi is then experiencing a dip in voltage, which is coming from whatever you have it connected to, I presume a wall adapter. What’s the output of that adapter? What’s the Amp rating on it? Is it a regulated or unregulated? The latter means with no load, it could very well be supplying ad much as 7-9V, and with a load it drops to 5V, however it also means it will dip rather low if something else comes on on the same circuit. Unfortunately there is no easy way to tell other than to measure its power output.
                    CGabo @dicker182
                    @dicker182
                    See my previous posting:
                    Probably the cause is some voltage / EMI feedback, likely due to the wires and switches. Try to switch on/off some lights and electrical devices and see the result!
                    To correct this condition, use a combination of current limiting, filtering and shielding.
                    Did you read the link?
                    https://www.raspberrypi.org/forums/viewtopic.php?t=53548
                    Try following:
                    • Reduce the cable length to the switch.
                    • Detect either only the rising (GPIO.RISING) or falling event.
                    • Use bouncetime in ms (minimum time between two callbacks in milliseconds (intermediate events will be ignored))
                    • Use a capacitor, see folowing example.
                      http://raspberrypihobbyist.blogspot.ch/2014/11/debouncing-gpio-input.html
                    • cruunnerrC
                      cruunnerr
                      after I install the module and type “pm2 restart mm” there is just a white screen. No UI loaded. Any idea?
                        dicker182
                        @All, sry for the lait answer, I followed all your guides, but I can´t solve the problem. I have to use another power circuit.
                        @cruunnerr, same here, you have to restart your pi. After the video starts for the first time, the bug is there. You can only reload mm when the video never starts in the same session.
                        • A
                          Andi1984
                          i tried to setup the button to watch the news with the MMM-Podcast module.
                          When i add the MMM-Button module to the config.js and start MM i only get an white screen.
                          With pm2 logs mm i get this
                          Loading config …
                          mm-0 Loading module helpers …
                          mm-0 No helper found for module: alert.
                          mm-0 WARNING! Could not load config file. Starting with default configuration. Error found : Error: Module version mismatch. Expected 49, got 46.
                          mm-0 App threw an error during load
                          mm-0 Error: Module version mismatch. Expected 49, got 46.
                          mm-0 at Error (native)
                          mm-0 at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                          mm-0 at Object.Module._extensions…node (module.js:568:18)
                          mm-0 at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                          mm-0 at Module.load (module.js:458:32)
                          mm-0 at tryModuleLoad (module.js:417:12)
                          mm-0 at Function.Module._load (module.js:409:3)
                          mm-0 at Module.require (module.js:468:17)
                          mm-0 at require (internal/module.js:20:19)
                          mm-0 at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/onoff/node_modu les/epoll/node_modules/bindings/bindings.js:76:44)
                          mm-0 Whoops! There was an uncaught exception…
                          Version mismatch from what?
                          Does someone know how to fix this?
                          • cruunnerrC
                            cruunnerr
                            Have the Same Problem. Take a Look here and Tell me if anything helped you.
                            https://forum.magicmirror.builders/topic/707/mmm-button-doesn-t-work
                            • A
                              Andi1984
                              Thanks for the link. I tried but the error is still there.
                              One thing changed.
                              Before:
                              Now:
                              Error: Module version mismatch. Expected 50, got 46
                              • A
                                Andi1984
                                Ok it is working now. I found this topic
                                link
                                Now when i prees the button i see the News on the screen.
                                Hope it will work for you too.
                                • F
                                  fox
                                  Dear community,
                                  how could i implement following scenario.
                                  Connect a button to the MM and switch monitor on and off with it?
                                  Issues With MMM-WatchDog known?
                                  https://forum.magicmirror.builders/post/29827
                                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
