    Rpi 0 W HELP
    5 Posts 3 Posters 2.1k Views 3 Watching
      djniuss
      HI ! i have tried all of the walktrough that i can fin to install MM on RPI0 W with no succes. is there a simple way to do this. im about to rip apart an old laptop to replace the pi0.
      Mykle1M 1 Reply Last reply
      • Y
        yawns Moderator
        Did you try this one? https://github.com/ac2799/MagicMirrorPi0Installer
        D 1 Reply Last reply
          djniuss @yawns
          @yawns I dont believe i did… will try first thing tonight when i get home. thank you . will follow up
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @djniuss
            @djniuss said in Rpi 0 W HELP:
            I’ve done this several times. Very satisfying. :-)
              djniuss
              ok so this did work. but i can only do it in server mode. so i have to open a page in chromium to see the miror ‘‘widget’’
              i also see the MM2 boot screen but then x in left upper corner and back to desktop.
              So any way to make this autorun ?
