    MMM-Spotify
    249 Posts 51 Posters 283.6k Views 54 Watching
    • Cr4z33C Offline
      Cr4z33
      @Sean OK maybe it is my fault, but it was my understanding that this Spotify module can be also a stand-alone player?
      For some reason a second try at Michael Jackson on Spotify made start the web player I was previously running on my computer…
      Does this mean that if I have Raspotify (how to set it up then?) I can actually run everything from the Pi?
        A Former User @Cr4z33
        @Cr4z33
        This is not a standalone player. you need “RASPOTIFY” to play songs directly on MM.
        There is some API about standalone player, but unfortunately, RPI doesn’t support that feature.
        Your trial was not about this module on RPI. It was an original features of Google Assistant.
        • Cr4z33C Offline
          Cr4z33 @Guest
          @Sean I want them both. ;)
          Voice commands to play Spotify songs STRAIGHT in MM.
          Thanks for confirming I am going to have some Raspotify reading now.
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer
            @Cr4z33 if you don’t want to use gaction like me .
            I’ll share my transcription hook and command i’m using with this module and others.
            It works perfectly. with raspotify. raspotify is pretty easy to install and run.
            transcriptionHook: {
                    HIDE_ALL_MODULES: {
                        pattern: "standby mode",
                        command: "HIDEMODULES"
                      SHOW_ALL_MODULES: {
                        pattern: "show modules",
                        command: "SHOWMODULES"
                      SCREEN_ON: {
                        pattern: "turn on screen",
                        command: "SCREENON"
                      SCREEN_OFF: {
                        pattern: "turn off screen",
                        command: "SCREENOFF"
                      REBOOT: {
                        pattern: "reboot the mirror",
                        command: "REBOOT"
                      SHUTDOWN: {
                        pattern: "extinction totale",
                        command: "SHUTDOWN"
                      STOP_PLAY: {
                        pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                        command: "STOP_VID"
                     // STOP_PLAY2: {
                     //   pattern: "arrête la musique",
                     //   command: "STOP_VID"
            	 SPOTIFY_PREVIOUS: {
                    pattern: "previous song",
                    command: "SPOTIFY_PREVIOUS"
                    SPOTIFY_PAUSE: {
                    pattern : "stop the musique",
                    command: "SPOTIFY_PAUSE"
                    SPOTIFY_PLAY: {
                    pattern : "music please",
                    command: "SPOTIFY_PLAY"
                    SPOTIFY_NEXT: {
                    pattern: "next song",
                    command: "SPOTIFY_NEXT"
                    SPOTIFY_VOLUME: {
                    pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                    command: "SPOTIFY_VOLUME"
                    SPOTIFY_SEARCH: {
                    pattern: "play (.*) on Spotify",
                    command: "SPOTIFY_SEARCH"
            	SPOTIFY_SEARCH_PLAYLIST: {
                    pattern: "playlist (.*) on Spotify",
                    command: "SPOTIFY_SEARCH_PLAYLIST"
            	SPOTIFY_MA_PLAYLIST: {
            	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
            	command: "SPOTIFY_MA_PLAYLIST"
            	SPOTIFY_TRANSFER: {
            	pattern: "play the music on (.*)", // (.*)  is the name of your device
            	command: "SPOTIFY_TRANSFER"
                      VOLUME_UP: {
                        pattern: "volume up",
                        command: "CMD_VOLUME_UP"
                      VOLUME_DOWN: {
                        pattern: "volume down",
                        command: "CMD_VOLUME_DOWN"
                      SET_VOLUME: {
                        pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                        command: "CMD_VOLUME_SET"
                    command: {
                      STOP_VID: {
                        moduleExec: {
                          module: ["MMM-AssistantMk2"],
                          exec: (module, params, key) => {
                            module.assistant.subdom.youtube.innerHTML = "";
                            module.assistant.subdom.youtube.style.display = "none";
                            module.youtubePlaying = false;
            	   SPOTIFY_TRANSFER: {
            	    notificationExec: {
                          notification: "SPOTIFY_TRANSFER",
            	         payload: (params) => {
                             console.log("SPOTIFY_TRANSFER @",params)
                            return params[1];
                       SPOTIFY_PAUSE: {
                        notificationExec: {
                          notification: "SPOTIFY_PAUSE"
                    SPOTIFY_PLAY: {
                        notificationExec: {
                            notification: "SPOTIFY_PLAY"
            	    notificationExec:  {
            		notification: "SPOTIFY_PLAY",
            		console.log("SPOTIFY_MA_PLAYLIST")
            		return {
            			context_uri:"spotify:playlist:0bdByehKVfdsfdsfdsOhF5t",   // Uri of a personnal playlist or album
            		notification: "SPOTIFY_SHUFFLE",  // added this to toogle shuffle
            		notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
            	SPOTIFY_NEXT: {
                     notificationExec: {
                    SPOTIFY_PREVIOUS: {
                     notificationExec: {
                        notification: "SPOTIFY_PREVIOUS"
                    SPOTIFY_VOLUME: {
                     notificationExec: {
                       notification: "SPOTIFY_VOLUME",
                             console.log("SPOTIFY_VOLUME @",params)
                            return params[1];
            	SPOTIFY_SEARCH: {
                     notificationExec: {
                       notification: "SPOTIFY_SEARCH",
                            console.log("SPOTIFY_SEARCH @",params)
                            return {
                                    type: "artist,track,album,playlist",
                                    query: params[1],
                                    random:false,
                     notificationExec: {
                            console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                            return {
                                    type: "playlist",
                                    query: params[1],
                                    random:true,
                      CMD_VOLUME_UP: {
                        notificationExec: {
                          notification: "VOLUME_UP"
                      CMD_VOLUME_DOWN: {
                        notificationExec: {
                          notification: "VOLUME_DOWN"
                      CMD_VOLUME_SET: {
                        notificationExec: {
                          notification: "VOLUME_SET",
                          payload: (params, key) => {
                            console.log("@", params);
                            return params[1];
            hope this will help.
            @Sean let me know if you want me to update the wiki.
            Ejay
            ? Cr4z33C 2 Replies Last reply Reply Quote 1
              A Former User @ejay-ibm
              @ejay-ibm thanks. As your wish, my colleague.
              • Cr4z33C Offline
                Cr4z33 @ejay-ibm
                @ejay-ibm thanks, but it came out that the module was already fine only I didn’t know I had to setup Raspotify if I want a stand-alone solution.
                Tbh you guys should state that as I guess many here would love to run Spotify completely from the mirror, but it is not so obvious. ;)
                • Cr4z33C Offline
                  Cr4z33
                  @Sean @ejay-ibm can you please add the option to hide module commands?
                  If someone like me is using MMM-AssistantMk2 to control it then buttons aren’t needed anymore. ;)
                  ejay-ibmE 1 Reply Last reply Reply Quote 0
                  • ejay-ibmE Offline
                    ejay-ibm Project Sponsor Module Developer @Cr4z33
                    @Cr4z33 We have added an option to hide the control
                    after doing a “git pull” from : ~/MagicMirror/modules/MMM-Spotify/
                    you can set in your config file
                     control: "default", //"default", "hidden" available~
                    Ejay
                    • Cr4z33C Offline
                      Cr4z33 @ejay-ibm
                      @ejay-ibm nice thanks! :thumbs_up_medium_skin_tone:
                      Also I didn’t notice in your last reply the many Spotify’ MMM-AssistantMk2 commands you were sharing.
                      Thanks for that too (although GA doesn’t understand properly yet when calling a specific Playlist, but hey we can’t have everything lol). :D
                      • Cr4z33C Offline
                        Cr4z33
                        @ejay-ibm @Sean I noticed only now that if using allowDevices: with the Raspotify device name I can then hear the music, but somehow the module doesn’t ‘wake up’ and keeps showing the Spotify logo only.
                        K Cr4z33C 2 Replies Last reply Reply Quote 0
                        • K Offline
                          kwaeksler @Cr4z33
                          @Cr4z33 thats true. That was one of my feature request on page one. I only wanted to see the information about the song on the mirror when i play it on it. Because for other familie members the information about my playing songs arent very interessting when i am not at home. :-D
                          • K Offline
                            kwaeksler
                            • K Offline
                              kwaeksler @Guest
                              @Sean said in MMM-Spotify:
                              updated
                              1.1.0 (2019-03-25)
                              • Added: touch(click) interface
                              • Device Limitation : Now you can allow or limit devices to display its playing on MM.
                              • Some CSS structure is changed.
                              • Now this module can emit SPOTIFY_* notifications for other module.
                              @Sean that sounds very great. I will update it later, thank you very much! :-)
                              • Cr4z33C Offline
                                Cr4z33 @Cr4z33
                                @Cr4z33 said in MMM-Spotify:
                                Guys any idea why? :grimacing_face:
                                Also @ejay-ibm maybe it’s because I translated them into Italian, but the commands used with MMM-AssistantMk2 that you posted earlier this week don’t get applied.
                                Ie. I say the hotword and then ‘next song’ and nothing happens…
                                Usually GA either executes the command or replies saying he didn’t understand, but not this time… :thinking_face:
                                alt text
                                • ejay-ibmE Offline
                                  @Cr4z33 1st you have a wonderfull miror
                                  2nd , if you send it to me maybe i’ll give you the answer ^^… joking …
                                  I’m not sure what’s wrong .
                                  What I would do first is turn on verbose mode on hotword and Mk2 assistant and check .
                                  1- Console log .
                                  2- pm2 out logs ( see “pm2 show scriptname” )
                                  3- pm2 error logs
                                  Capitalization is very important in hook eg .
                                  hook is like “next song”
                                  when you say this to assistant if assistnat wirte " Next song" that that wikk not work .
                                  All I can say for now is check the logs and share with us , that mitght help to help .
                                  Ejay
                                  • I Offline
                                    icripps
                                    can whatever that is playing on your phone be played by the mirror too?
                                      A Former User @icripps
                                      @icripps
                                      If you mean multi-speaker, It isn’t.
                                      To play Spotify on your MagicMirror(Raspberry Pi), you need to install Raspotify on your Raspberry Pi.
                                      Then, you can play Spotify on your MM directly and can control Spotify (Wherever it played on).
                                      • Cr4z33C Offline
                                        Cr4z33 @ejay-ibm
                                        @ejay-ibm lol for my mirror and thanks for the suggestion. :smiling_face_with_open_mouth_closed_eyes:
                                        @icripps please note that to be able to use Raspotify a Spotify Premium account is MANDATORY. ;)
                                        • I Offline
                                          icripps
                                          Okay thank you. Will manage what I have for now
                                            bolish
                                            Hi guys,
                                            Do you know which parameter to play with into the custom.css to get the module smaller in size? (it’s taking to much place on my screen).
                                            Thx
                                            • 12
                                            • 13
                                            • 2 / 13
