    Wheather/ Wunderground not loading
    17 Posts 10 Posters 9.4k Views 10 Watching
      chris1971
      Thanks - then I have to try another module and update MM2…
      Hope it works out…
        Medo
        The API was shut down. Heres the official statement (from: https://feedback.weather.com/customer/en/portal/articles/2970681-my-weather-underground-api-key-has-been-disabled-why-?b_id=17298)
        ***My Weather Underground API key has been disabled. Why?
        The Weather Underground’s API has been retired. Keys have been closed down on a rolling basis since February 15, 2019. It will close down completely shortly. Information about this has been available through the API itself and online for nearly a year.
        If you are a contracted, paying customer and feel you have been shut off in error, please click the blue ‘email us’ button below.
        If you would like to explore paid plans on The Weather Company’s enterprise-grade API, please follow this link and fill out the form on that page.
        At this time we do not anticipate offering free, ongoing “developer” level keys to The Weather Company’s API.
        Thank you for your support of the Weather Underground API.***
        Alternatives?
        B 1 Reply Last reply Reply Quote 2
        • K Offline
          kasperb
          Thanks.
          Does anyone have suggestions on the next best alternative? I feel like weather underground was relatively accurate, unlike some of the other options out there.
            Medo @kasperb
            @kasperb: I will give this module a try:
            https://github.com/cowboysdude/MMM-NOAA3
            It has several options for placing API (weatherdata). So if one closes - i can switch to the next if needed…
            I installed it today so i cannot say if the data (from weatherbit.io in my case) is reliable…
              Mykle1 Project Sponsor Module Developer @Medo
              @Medo et al,
              You can also use the darksky api with NOAA3. I find this to be very accurate for my location
                Dommer
                I have found that DarkSkyForecast has been an excellent replacement for the Wunderground module. Format and display looks very similar. I have been using it for a few weeks and I am very happy with it. API keys for DarkSky are free for up to 1000 calls a day. So if you refresh the weather every 15 mins, thats only 96 calls a day.
                Check it out
                https://forum.magicmirror.builders/topic/9181/mmm-darkskyforecast-yet-another-weather-module
                  bhepler Module Developer @Medo
                  @Medo - Yeah, my free API key was shut down last week.
                  • T Offline
                    thobach
                    I migrated my MMM-WunderGround24Hours module also to use the Dark Sky API and it is now available at https://github.com/thobach/MMM-DarkSky24Hours. The migration was super easy.
                      coloradokb
                        coloradokb @bhepler
                        @bhepler
                        May be missing the mark here, but what I’m seeing is if you had a key w/weatherunderground, it’s definitely gone. However, generating keys seems to still be an option. Perhaps I’m grandfathered in.
                        Mine isn’t loading either. With newly (longer) generated api key from WU api-key form, there’s documentation showing weather.com returning content. New URL and json below. I’ll try to see about adjusting code to handle new response. I’m new to this module and may not have time for a few days. Hope this helps and if someone could verify that’d be especially helpful.
                        https://api.weather.com/v2/pws/observations/current?stationId=KMAHANOV10&format=json&units=e&apiKey=keyhere
                        {“observations”:[{“stationID”:“KMAHANOV10”,“obsTimeUtc”:“2019-03-27T03:17:53Z”,“obsTimeLocal”:“2019-03-26 23:17:53”,“neighborhood”:“1505Broadway”,“softwareType”:“Rainwise IP-100”,“country”:“US”,“solarRadiation”:null,“lon”:-70.86485291,“realtimeFrequency”:null,“epoch”:1553656673,“lat”:42.09263229,“uv”:null,“winddir”:270,“humidity”:71,“qcStatus”:1,“imperial”:{“temp”:24,“heatIndex”:24,“dewpt”:16,“windChill”:24,“windSpeed”:0,“windGust”:0,“pressure”:30.30,“precipRate”:0.00,“precipTotal”:0.00,“elev”:104}}]}
                        LusbuebL 1 Reply Last reply Reply Quote 2
                        • LusbuebL Offline
                          Lusbueb @coloradokb
                          @coloradokb
                          Yes with the new API key you get current weather data and also forecast. However, most variables have changed their name and you have to adjust the code of “MMM-WunderGround.js” and “node_helper.js”.
                          Examples:
                          apiBase old: “http://api.wunderground.com/api/”
                          apiBase new: “https://api.weather.com/”
                          forecast old: “http://api.wunderground.com/api/yourApiKey/conditions/hourly/forecast10day/astronomy/alerts/lang:DL/q/pws:ISAFENWI13.json”
                          forecast new: "https://api.weather.com/v3/wx/forecast/daily/5day?postalKey=81657:US&units=e&language=en-US&format=json&apiKey=yourApiKey
                          Variables:
                          old: wind_mph
                          new: windspeed
                          old: relative_humidity
                          new: relativeHumidity
                          The effort to rewrite the existing code is very large, unfortunately I’m not a programmer :(
                          greetings from Switzerland
                          Peter
                          (translated with Google)
