    updated installer script available for testing
    211 Posts 18 Posters 319.4k Views 19 Watching
      I tip my hat to you for taking the initiative. I could, if you wanted, take a laptop with ubuntu on it and test it for you now. It’s not a big deal. Just say the word. :thumbsup:
        I’m just gonna do it. I’ll report back in a bit.
        EDIT MINUTES LATER:
        It appears I jumped the gun here. This was intended for Pi users only? Sorry bro. The only Pi I have is running my first mirror and I wouldn’t touch that.
        pop@CQ57:~$ bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
        bash: “#!/usr/bin/env: No such file or directory
        pop@CQ57:~$
          sdetweil @Mykle1
          @Mykle1 try now… I commented out the PI test
            Will do. Gonna do that now. I will report back.
            EDIT:
            I used the same url and got the same error as noted above. Perhaps I am doing something wrong?
              sdetweil @Mykle1
              @Mykle1 redo the cut/paste… the original had the funky double quotes in it…
                Just to be clear. I ran the original command twice. No luck.
                I copy and pasted it a third time when you said you have commented out things. No luck same error.
                Then I copied the script itself into a file and renamed it raspberry.sh and made it executable by chmod u+x raspberry.sh and saved that to home and ran the install script again. No luck. Same error.
                I’m sorry I’m not being much help
                  sdetweil @Mykle1
                  @Mykle1 ok, again… that was the 1st line… why that way, not sure… try again
                  but I know why it was done, altho I don’t think that is needed…
                    Ok, its running now. I failed to fix the bad quotes so that may have been the problem with my first 3 attempts. I will report when it completes
                      Check plymouth installation ...
                      Splashscreen: Checking themes directory.
                      Splashscreen: Create theme directory if not exists.
                      Splashscreen: Theme copied successfully.
                      sudo: plymouth-set-default-theme: command not found
                      Splashscreen: Couldn't change theme to MagicMirror!
                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                      I’m choosing yes and continuing
                        [PM2] Remove init script via:
                        $ pm2 unstartup systemd
                        [PM2] Spawning PM2 daemon with pm2_home=/home/pop/.pm2
                        [PM2] PM2 Successfully daemonized
                        [PM2][WARN] Applications MagicMirror not running, starting...
                        [PM2] App [MagicMirror] launched (1 instances)
                        │ App name    │ id │ version │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                        │ MagicMirror │ 0  │ 2.6.0   │ fork │ 1976 │ online │ 0       │ 0s     │ 0%  │ 3.0 MB   │ root │ enabled  │
                         Use `pm2 show <id|name>` to get more details about an app
                        [PM2][ERROR] Permission denied, to give access to current user:
                        $ sudo chown pop:pop /home/pop/.pm2/rpc.sock /home/pop/.pm2/pub.sock
                        Do you want to disable the screen saver? (y/N)?
                        Im choosing no and continuing
                          We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                          pop@CQ57:~$
                          Mirror started automatically. No need to run a command. No need to create a config. Nice work Sam
                            @sdetweil said in Anyone want to try updated installer...:
                            Just in case anyone else wants to test this, don’t use the example in the original post. Try this instead:
                            bash -c "$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)"
                              sdetweil @Mykle1
                              @Mykle1 but I fixed the original post
                              ah, i see, needs to be in the backtics to preserve the quotes…
                              fixed AGAIN!
                                the new installer referenced here is now part of the base at 2.8.0, released July 1, 2019
                                  You’re awesome! :thumbsup:
                                    sdetweil @Mykle1
                                    @Mykle1 not my point, or interest.
                                    Don’t follow links in this topic anymore.
                                    StoffbeuteluweS Mykle1M 2 Replies Last reply Reply Quote 0
                                    • StoffbeuteluweS Offline
                                      Stoffbeuteluwe Project Sponsor @sdetweil
                                      @sdetweil now the Automatic installer works for Mac and Windows…is that right?
                                        sdetweil @Stoffbeuteluwe
                                        @Stoffbeuteluwe it should… i have not tried on windows.
                                          @sdetweil have you tried on Mac ?
                                          does it work with pm2
                                            @Stoffbeuteluwe looks like it doesn’t,
                                            working on it
                                            • 10
                                            • 11
                                            • 1 / 11
