    updated installer script available for testing
    211 Posts 18 Posters 285.8k Views 19 Watching
      I tip my hat to you for taking the initiative. I could, if you wanted, take a laptop with ubuntu on it and test it for you now. It’s not a big deal. Just say the word. :thumbsup:
        I’m just gonna do it. I’ll report back in a bit.
        EDIT MINUTES LATER:
        It appears I jumped the gun here. This was intended for Pi users only? Sorry bro. The only Pi I have is running my first mirror and I wouldn’t touch that.
        pop@CQ57:~$ bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
        bash: “#!/usr/bin/env: No such file or directory
        pop@CQ57:~$
          sdetweil @Mykle1
          @Mykle1 try now… I commented out the PI test
            Will do. Gonna do that now. I will report back.
            EDIT:
            I used the same url and got the same error as noted above. Perhaps I am doing something wrong?
              sdetweil @Mykle1
              @Mykle1 redo the cut/paste… the original had the funky double quotes in it…
                Just to be clear. I ran the original command twice. No luck.
                I copy and pasted it a third time when you said you have commented out things. No luck same error.
                Then I copied the script itself into a file and renamed it raspberry.sh and made it executable by chmod u+x raspberry.sh and saved that to home and ran the install script again. No luck. Same error.
                I’m sorry I’m not being much help
                  sdetweil @Mykle1
                  @Mykle1 ok, again… that was the 1st line… why that way, not sure… try again
                  but I know why it was done, altho I don’t think that is needed…
                    Ok, its running now. I failed to fix the bad quotes so that may have been the problem with my first 3 attempts. I will report when it completes
                      Check plymouth installation ...
                      Splashscreen: Checking themes directory.
                      Splashscreen: Create theme directory if not exists.
                      Splashscreen: Theme copied successfully.
                      sudo: plymouth-set-default-theme: command not found
                      Splashscreen: Couldn't change theme to MagicMirror!
                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                      I’m choosing yes and continuing
                        [PM2] Remove init script via:
                        $ pm2 unstartup systemd
                        [PM2] Spawning PM2 daemon with pm2_home=/home/pop/.pm2
                        [PM2] PM2 Successfully daemonized
                        [PM2][WARN] Applications MagicMirror not running, starting...
                        [PM2] App [MagicMirror] launched (1 instances)
                        │ App name    │ id │ version │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                        │ MagicMirror │ 0  │ 2.6.0   │ fork │ 1976 │ online │ 0       │ 0s     │ 0%  │ 3.0 MB   │ root │ enabled  │
                         Use `pm2 show <id|name>` to get more details about an app
                        [PM2][ERROR] Permission denied, to give access to current user:
                        $ sudo chown pop:pop /home/pop/.pm2/rpc.sock /home/pop/.pm2/pub.sock
                        Do you want to disable the screen saver? (y/N)?
                        Im choosing no and continuing
                        • 21
                        • 22
                        • 1 / 22
