    Google assistant on magicmirror
    google assistantmagicmirror
    21 Posts 8 Posters 21.1k Views 9 Watching
      clconner09
      Same problem here although mine doesn’t appear to trigger at all. I’ve gotten the sample to run. I can run assistant.py and interact but when altering the config file and running MM. Nothing but an icon at the top.
      ChrisC 1 Reply Last reply
      • ChrisC
        Chris @clconner09
        @clconner09
        I was unfortunately forced to give up. After several installations, always the same problem.
        I will wait to see if the developer of this great module will update soon.
        cordially,
        gauravsaccG 1 Reply Last reply
        • gauravsaccG
          gauravsacc Module Developer @Chris
          @Chris A bit late but the module is updated now. Go ahead and pull the update, let me know if you are still facing issues. Happy to help!
          H 1 Reply Last reply
          • ChrisC
            Chris
            @gauravsacc
            I tried a git pull on the module MMM-Assistant but I still encounter the same problem. The voice is still jerky in English while I wish in French.
            there is a good chance that I made a mistake during the installation but I can not find where.
            Are you a beginning of track to communicate to me?
            Thank you in advance,
            • H
              hrjmsh @gauravsacc
              @gauravsacc First, many thanks for such an excellent effort. Unfortunately, despite having the latest and updated module version, I am having the same ‘no start’ issue in Magic Mirror as others have mentioned. I can start ‘assistant.py’ under “source env/bin/activate” and it works absolutely fine while staying in the terminal. But once in Magic Mirror, the google assistant remains unresponsive. Does ‘assistant.py’ needs to run as a script in the background at startup or is there anything else I am missing?
              • gauravsaccG
                gauravsacc Module Developer @hrjmsh
                @hrjmsh Yes assistant.py should be running in the background
                • H
                  hrjmsh @gauravsacc
                  @gauravsacc Great, thanks. All working fine.
                  It might be a good idea to include that information in your module page at the end of instructions. It would help a lot to a novice and inexperienced like me!
                  • gauravsaccG
                    @hrjmsh sure you want to raise a pull request with this change?
                    • O
                      onurcnbs
                      I did all the current steps. GA worked. But the Smart mirror is not active. Only the GA symbol appears. I’m having trouble with assistant.py. Can you help?
                        See MMM-AssistantMk2
                        has GA and can execute actions on mirror
