    BBC News feed
    10 Posts 3 Posters 7.9k Views 3 Watching
    • T Offline
      TamP
      Yes isnt it. I try this and it didnt seem to do anything
      Its not a big deal but I just wonder if I had done something wrong
      • justjim1220J Offline
        justjim1220 Module Developer
        there is an omission in the newsfeed.js file, that is causing this problem…
        this secton:
        if(!this.config.showFullArticle){
                var title = document.createElement("div");
        	title.className = "bright medium light" + (!this.config.wrapTitle ? " no-wrap" : "");
        	title.innerHTML = this.newsItems[this.activeItem].title;
        	wrapper.appendChild(title);
        states if(!this.config.showFullArticle){
        But there isn’t a showFullArticle: false; in 'defaults
        So, basically it is ignoring the showSourceTitle: true, because this section cannot be executed
        I think it would make more sense to have the above code snippet be worded like this:
        if(this.config.showSourceTitle){
        then maybe add:
        showSourceTitle = false;
        to this section of code:
        if (this.config.showFullArticle) {
        	var fullArticle = document.createElement("iframe");
        	fullArticle.className = "";
        	fullArticle.style.width = "100vw";
        	// very large height value to allow scrolling
        	fullArticle.height = "3000";
        	fullArticle.style.height = "3000";
        	fullArticle.style.top = "0";
        	fullArticle.style.left = "0";
        	fullArticle.style.border = "none";
        	fullArticle.src = this.getActiveItemURL()
        	fullArticle.style.zIndex = 1;
        	wrapper.appendChild(fullArticle);
        if you don’t want the title to display while the article is being displayed.
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
        • T Offline
          TamP @justjim1220
          @justjim1220 I tried altering the code as you suggest but unfortunately I am still not seeing the BBC title
          • T Offline
            TamP
              justjim1220 Module Developer @TamP
              @TamP
              you might try deleting the module then reinstalling it
              I just tried exactly what you have configured and it works just fine…
              Since newsfeed is a part of the initial MM2 installation, go here: https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
              and get the newsfeed files themselves. You probably only need the actual js files: fetcher.js & newsfeed.js
              right click on the file and click Save Link As… then save to your newsfeed directory within MM2
              Jim Hallock - 1995
              • T Offline
                TamP @justjim1220
                @justjim1220 Yes that is what I did and all is OK
                Thanks again
