    BBC News feed
    10 Posts 3 Posters 8.8k Views 3 Watching
    • T
      TamP
      I cant seem to find an up to date BBC news feed
      Min is showing news from 3 years ago !!!
      Can anyone help ?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @TamP
        @TamP
        There are a bunch on this page. I tested the first one and it fired right up.
        https://blog.feedspot.com/bbc_rss_feeds/
        Copy the RSS Feed url of your choice and add it to your config…
        • T
          TamP
          Thanks for that, I have it displayed now, except the title is not showing. This is what I have in the config
          // Newsfeed BBC
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "BBC UK",
          					 	url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
          						title: "BBC World",
          					    url: "http://feeds.bbci.co.uk/news/world/rss.xml",
          				showSourceTitle: true,
          				showPublishDate: false,
          				showDescription: true
          • Mykle1M
            @TamP said in BBC News feed:
            That’s odd. I can’t make the title go away. Even with all three of these set to false:
            showSourceTitle: false,
            showDescription: false
            • T
              TamP
              Yes isnt it. I try this and it didnt seem to do anything
              Its not a big deal but I just wonder if I had done something wrong
              • justjim1220J
                justjim1220 Module Developer
                there is an omission in the newsfeed.js file, that is causing this problem…
                this secton:
                if(!this.config.showFullArticle){
                        var title = document.createElement("div");
                	title.className = "bright medium light" + (!this.config.wrapTitle ? " no-wrap" : "");
                	title.innerHTML = this.newsItems[this.activeItem].title;
                	wrapper.appendChild(title);
                states if(!this.config.showFullArticle){
                But there isn’t a showFullArticle: false; in 'defaults
                So, basically it is ignoring the showSourceTitle: true, because this section cannot be executed
                I think it would make more sense to have the above code snippet be worded like this:
                if(this.config.showSourceTitle){
                then maybe add:
                showSourceTitle = false;
                to this section of code:
                if (this.config.showFullArticle) {
                	var fullArticle = document.createElement("iframe");
                	fullArticle.className = "";
                	fullArticle.style.width = "100vw";
                	// very large height value to allow scrolling
                	fullArticle.height = "3000";
                	fullArticle.style.height = "3000";
                	fullArticle.style.top = "0";
                	fullArticle.style.left = "0";
                	fullArticle.style.border = "none";
                	fullArticle.src = this.getActiveItemURL()
                	fullArticle.style.zIndex = 1;
                	wrapper.appendChild(fullArticle);
                if you don’t want the title to display while the article is being displayed.
                Jim Hallock - 1995
                T 1 Reply Last reply
                • T
                  TamP @justjim1220
                  @justjim1220 I tried altering the code as you suggest but unfortunately I am still not seeing the BBC title
                  justjim1220J 1 Reply Last reply
                  • T
                    TamP
                    • justjim1220J
                      justjim1220 Module Developer @TamP
                      @TamP
                      you might try deleting the module then reinstalling it
                      I just tried exactly what you have configured and it works just fine…
                      Since newsfeed is a part of the initial MM2 installation, go here: https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
                      and get the newsfeed files themselves. You probably only need the actual js files: fetcher.js & newsfeed.js
                      right click on the file and click Save Link As… then save to your newsfeed directory within MM2
                      Jim Hallock - 1995
                      • T
                        TamP @justjim1220
                        @justjim1220 Yes that is what I did and all is OK
                        Thanks again
