    MMM-MyStandings
    24 Posts 12 Posters 15.5k Views 13 Watching
    • V Offline
      vinp Module Developer
      Hi - I created a new module to display sports standings for the NHL, MLB, NFL, and NBA. I really enjoy using the module MMM-MyScoreboard so I wanted to make a similar looking one to help me keep track of standings.
      https://github.com/vincep5/MMM-MyStandings
      The display will rotate through the sports if you have chosen to include more than 1 sport.
      [card:vincep5/MMM-MyStandings]
        MMKF
        is there any way to keep it restricted to a certain position on the screen? or to cycle a smaller amount (say display just a division at a time and cycle those?) When displaying all teams it just gets enormous for me. Thanks!
        example
        • V Offline
          Good idea. I will look into that. I had a spare old LCD TV which I made into a Magic Mirror display, so I had the real estate to see all the teams and divisions :). The project is open for PR if there is any interest from anyone in helping.
          The config does allow seeing certain divisions in each sport, but not exactly what you were looking for.
            MMKF @vinp
            @vinp yeah i’m just using an old laptop monitor. For hockey, I like to see all the standings, whereas NFL and MLB just my local divisions. College football TOP25 / conferences would be awesome come the fall too. Thanks for the hard work!
            • V Offline
              vinp Module Developer @MMKF
              @MMKF Thanks for the feedback. I have updated the code to show one division at a time. I realize that is better for most users. Try a git pull inside the MMM-MyStandings folder again, as far as it being too wide, you can try overriding the .MMM-MyStandings class in your custom.css to control width.
              • V Offline
                I’ve updated the code to include the option to load logos from local folders. It mimics the way MMM-MyScoreboard does it. This way the logos will look the same if you use both modules. I also made it easier in the future to add more sports that don’t have divisions. Lastly, I added MLS as a sport option.
                  Jfarro
                  Thankyou for your work on this, I’m running it and it was easy to setup, has a great amount of options, and is beautiful! Now if my sports teams would do their part and not be at the bottom, that’d be great :)
                  • V Offline
                    Thanks for the feedback ! Glad you are enjoying it. I love seeing sports updates on the mirror!
                      my_nerdy_account
                      I love this module! Thanks so much for sharing it.
                      I’ve modified the css and .njk template to something I really like. What I need now is for the leagues to rotate through in a specific order. It seems like they load in a random order every time I restart MM.
                      FLhTF V 2 Replies Last reply Reply Quote 1
                      • FLhTF Offline
                        FLhT @my_nerdy_account
                        These are Cool! I’m inspired to (eventually) adapt this to display FIRST Tech Challenge and FIRST Robotics Competition Stats.
                          alecbalec
                          Great module, I forked it on github and added the English Premier League.
                          • V Offline
                            vinp Module Developer @my_nerdy_account
                            @my_nerdy_account that looks awesome! Care to share your branch in GitHub?
                            • V Offline
                              vinp Module Developer @alecbalec
                              @alecbalec I’m testing out the ability to add many more soccer leagues… stay tuned for an update
                              • V Offline
                                I’ve added NCAAM Basketball and lots of different Soccer leagues from ESPN. It should be able to handle all the soccer leagues that have standings/tables available. I looked at how MMM-MyScoreboard did the soccer leagues and used the same naming. Have a look at my code (get latest) and let me know how it goes. thanks!
                                • N Offline
                                  Newtothis
                                  @vinp Hi
                                  Thanks for the module, really enjoying it and thanks for updating it. I was just wondering if it is possible to have two leagues showing at the same time?
                                  I tried using two instances of the configuration (One for NBA and one for Premier League) in the config.js but this didn’t work. Very new at all of this, so please excuse me if it is really obvious answer
                                  Thanks!
                                  V 1 Reply Last reply Reply Quote 2
                                  • V Offline
                                    vinp Module Developer @Newtothis
                                    @Newtothis I dont think this module supports that. I think I read on this forum that if the module uses a node_helper.js it wont be possible. Otherwise you could try copying and renaming a similar folder and setup the MM config with both names. There is a issue logged on my github with your same suggestion. I just haven’t had the chance to look to see how much effort it would take to implement.
                                      sdetweil @vinp
                                      @vinp said in MMM-MyStandings:
                                      it IS possible… just have to think thru the choices of the solution…
                                      there is only ONE node_helper loaded for all instances of the module.
                                      any sendSocketNotification from the helper to the module (instances) goes to ALL instances at once.
                                      so, one could send the module identifier from the module.js to the node_helper, and use THAT as a key into a storage area saved by module instance (config from module _1, module_2, etc)…
                                      config: {},
                                      this.config[module_id].config_variable
                                      and then on the send BACK, return the module identifier as part of the data, and the module checks to see if the response is for that instance…
                                      another way, to avoid the storage, is for the module to send config every time, and the identifier, and
                                      the node helper send back the identifier as part of the response… and module checks… same as before…
                                      I created a module that does option 2 , never stores any module instance data in node_helper
                                      https://github.com/sdetweil/NewBusTimes
                                      N 1 Reply Last reply Reply Quote 1
                                      • cowboysdudeC Offline
                                        Excellent!
                                        • N Offline
                                          Newtothis @sdetweil
                                          @sdetweil Thank you!
                                          I managed to get it working by renaming the module and replacing all instances of the module name with something different.
                                          I am having trouble getting ‘ENG_NATIONAL’, ‘ENG_LEAGUE_1’ AND ‘ENG_LEAGUE_2’ tables to appear, do you have any ideas on how to get them working?
                                          Thank you
                                          S V 2 Replies Last reply Reply Quote 0
                                            sdetweil @Newtothis
                                            @Newtothis sorry. No idea how the module works
