    MMM- EARTH not starting
    9 Posts 4 Posters 2.7k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @chris1971
      @chris1971 hi Chris , your config is ok it works fine for me…have you done npm install in the MMM-EARTH directory??
      i had the same problem, but after new install of the module it works fine
        Mykle1 Project Sponsor Module Developer @chris1971
        @chris1971
        start your mirror using npm start dev and report any errors from the console log there, if any. I am not seeing this behavior, although some times (rarely) the API can be the problem.
          chris1971
          Thanks guys.
          I switched over to MMM Globe and will try MMM Earth maybe later… Will keep you informed.
          Thanks for your help.
          Regards, Chris
            chris1971
            So I tried it again… with npm start dev I got this:
            Uncaught TypeError: console.log is not a function
                at Class.scheduleCarousel (MMM-EARTH.js:155)
                at Class.socketNotificationReceived (MMM-EARTH.js:182)
                at module.js:246
                at r.<anonymous> (socketclient.js:25)
                at r.emit (index.js:83)
                at r.onevent (index.js:83)
                at r.MMSocket.self.socket.onevent (socketclient.js:19)
                at r.onpacket (index.js:83)
                at r.<anonymous> (index.js:83)
            Are you able to “encrypt”?
            Thx, Chris
              @chris1971
              Hmm, I am not seeing this at all. Suggestions:
              1. Use only unmodified modules
              2. Add one module at a time to the defaults to determine which module is causing the problem
              3. Add only MMM-EARTH to the default modules and see if the problem still occurs
                chris1971
                You are right - I removed MMM GoogleTrafficMaps and the MMM Earth is working… Now I have the challenge to understand what’s happening…
                Chris
                  sdetweil @chris1971
                  @chris1971 I suspect that there is a variable naming problem between the two modules… the javascript namespace is all one big library… so, if module A uses a variable name and module B uses the SAME variable name, oops… last one in wins…
                  if you move the module entries in config.js around so, whichever is last now is closer to the top does the behavior change?
                    chris1971
                    I changed the positions in the config.js . No change visible.
