    My first cheap £70 attempt :)
    6 Posts 3 Posters 7.5k Views 3 Watching
    • T Offline
      TipsyNurse
      Firstly, thank you to all of you for your contributions, I learnt a lot reading this forum :)
      Got interested in MagicMirror when looking at ways to display ambulance and pharmacy information at work. Unfortunately couldn’t use it there in the end because one of the Chief Nurses didn’t get Linux and kept insisting it was Windows because it had a desktop and so my security analysis was wrong. Ooookay… their loss.
      Anyway, thought I would cobble something together with a Pi and old IPS monitor I had at home. I want to do a proper mirror one with a much larger screen and the plug sockets hidden behind as well but thought I would experiment a bit first.
      Quite pleased at how it has turned out. It is genuinely useful rather than just being a gimmick. Looking forward to my second!
      alt text
      and this is my config
      			module: "alert",
        module: "MMM-GooglePhotos",
        position: "fullscreen_below",
          albumId: ["xxx"], // your album id(s) from result of `auth_and_test.js`
          refreshInterval: 1000*60,
          scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
          //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
          sort: "random", //'time', 'reverse', 'random'
          showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
          showHeight: "100%",
          originalWidthPx: 1920, // original size of loaded image. (related with image quality)
          originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
          mode: "cover", // "cover" or "contain"
          //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
      			module: 'MMM-GoogleCast',
      			position: "bottom_left",
      			classes: "default everyone",
      				device: "xxx",
          module: 'MMM-Remote-Control'
           , position: 'bottom_left',
              customCommand: {},  // Optional, See "Using Custom Commands" below
              customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              apiKey: "",         // Optional, See API/README.md for details
      			module: "updatenotification",
      			position: "top_bar"
      			header: "Family calendar",
      						symbol: "calendar-check",
      						url: "xxx.ics"
      wrapEvents: true,
      maxTitleLines: 2,
      fadePoint: 0.8,
      displaySymbol: false,
      dateFormat: "Do MMM",
      maximumEntries: 9,
      			module: "clock",
      			position: "top_bar",
      displayType: "analog",
      analogShowDate: "false",
      analogSize: "590px",
      analogFace: "face-003",
              module: 'MMM-Tado',
              position: 'bottom_left', // This can be any of the regions.
                  username: 'xxx@',
                  password: 'xxx',
                  updateInterval: 300000
        module: "MMM-DarkSkyForecast",
        header: "Weather",
        position: "bottom_right",
        disabled: false,
          apikey: "xxx",
          latitude: "51.xxxxxx",
          longitude: "-1.xxxxxx",
          iconset: "1c",
          concise: true,
          forecastLayout: "tiled"
        module: 'MMM-MyGarbage',
        position: 'bottom_center',
                weeksToDisplay: 1,
                limitTo: 99,
                fade: false,
                dateFormat: "'Recycling this week' [This week]",
                fadePoint: 0.25
      		module: 'MMM-Screencast',
      			position: 'center',
      			height: 600,
      			width: 1000,
      • T Offline
        TipsyNurse
        Sorry I can’t work out how to edit the post, this is some strange forum software.
        Right way round photo :)
        alt text
        Mykle1M N 2 Replies Last reply Reply Quote 2
          Mykle1 Project Sponsor Module Developer @TipsyNurse
          @TipsyNurse
          For an experiment, I would say, it came out rather nicely. Well done.
          • N Offline
            nobita @TipsyNurse
            @Tipsy
            Hello very nice mirror
            How to set border and background around your module in mirror
            • T Offline
              TipsyNurse @nobita
              @nobita in your css/custom.css file
              .module {
                background-color:rgba(0,0,0,0.3);
                border-radius:8px;
                padding:8px;
              You can adjust the 0.3 towards 0 (transparent) or 1 (opaque). Hope that helps :)
              • T Offline
                TipsyNurse
                Oh, also, if you want a “glass” type button you can use box-shadow. I’m never sure which I prefer and tend to swap periodically.
                .module {
                  background-color:rgba(0,0,0,0.25);
                  border-radius:8px;
                  box-shadow: inset 0 3px 6px rgba(0,0,0,0.16), 0 4px 6px rgba(0,0,0,0.45);
                  padding:8px;
